Results 1 to 7 of 7
Thread: Losing playlist on switch from radio to music
    May 2007
    Forgive me if this posted somewhere else, but none of the searches I did turned up any hits.
    The problem I'm having is whenever I switch to music while the radio is playing, my playlist is empty, even if it was previously full of songs. I noticed I only have this problem when I'm using the linein plugin for Winamp. If I don't use this option, it's not a problem. I'd like to use the linein plugin for a few reasons, but I can't seem to figure out a workaround.
    I think this has something to do with winamp.m3u as well, but I don't think Winamp is saving the current playlist to this file properly.
    It seems to me that when the radio is turned on it clears the playlist and then when it switches back to the music, Winamp forgets what the original play list was.
    If I have music playing and shutdown or exit and restart RR, the playlist is fine, only when switching from the radio while using the linein plugin does it crap out.
    Any ideas?
    I'm using Winamp 5.13 and the latest RR and DFX 4.0.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I've had the same issue myself, and it's inconsistent, sometimes it does it and sometimes it doesn't. It's gotten worse with the 9-10-08 build of RR.
    May 2007
    Quote Originally Posted by Machinehead View Post
    Odd. I would think the problem would be with Winamp and the linein plugin and not so much with RR, but I could be wrong (Hence posting here).
    Jun 2007
    The linein plugin is trouble some, it used to cause problems with music resume. It looks like Mitch fixed that problem in the latest RR build.
    MySQL Error
    Oct 2004
    nitefalls, its working PERFECT
    DFX4 use RRmedia, maybe bug there? i dont know too much about it
    im using TECNIK2 (one cool skin, dx4 is neat but BUSY), and when i go back and forth from HD Radio to MP3s, my playlist is always there, and mp3s resume right where it left off
    now im USING winamp V5.53 + JASPER'S LINE IN PLUGIN V1.80
    machinehead, you assume too much, very little out side of XM Radio/ Sirius Radio / HD Radio has changed, in my RR build which is based off 5/27/08 RR Code, so if the issue is in 5/27 code, it could be here. I have gotten EVERY bug fixed, that was properlly brought to my attention
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mar 2004
    Ive had this problem since last spring with multiple windows installs. It only saves my road runner stuff (song & position, random/repeat settings) when I hit the exit button.
    I'm using the december version and don't have any plugins installed
    MySQL Error
    Oct 2004
    dyne, its something in winamp...
    it works here, and i got the lamest setup
    since im not even using it on a carpc
    make sure files are writeable in winamp dir
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 04:01 PM
  2. Replies: 4
    Last Post: 06-27-2008, 08:38 PM
  3. M2 pic chip? can we program custom times?
    By 89ragtopgt in forum Power Supplies
    Last Post: 01-22-2008, 09:24 AM
  4. dlink radio playlist
    By gerard in forum ME Archive
    Last Post: 12-16-2003, 04:33 PM
