Results 1 to 8 of 8
Thread: Reducing volume for speech directions
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Im using the newest version of RR and Streets and Trips 2008. The voice direction works, but RR won't reduce the volume of the music when the voice comes over. I tried different % values in RR config. After I save and exit the config, it goes back to unchecked. Anything else I change in RR saves except for this option. Any ideas on that?
    Jul 2008
    I've got the same problem but opposite... I want to lower the voice volume! it sounds extremely high...
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Search for NaviMon2
    Nov 2007
    North Central PA
    Ok, I installed NaviMon2 and it didn't work. I have RR config set up to only control the main volume. Is that a problem?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    NaviMon2 controls the winamp volume when there is activity at the wave volume.
    Ther is also a second command which can be about anything RR can handle. Look through the NaviMon thread.
    Nov 2007
    North Central PA
    I worked with it again last night. It seems that the voice has increased in volume now. However, the music volume doesn't noticably decrease. Its not bad. Now, at least I can hear and understand the voice commands. I was woundering about NaviMon. The readme file says to install it in the RR folder. If it controls winamp, shouldn't it be installed in the winamp folder?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    No, it just gives Road Runner commands.
    SETVOL;WINAMP;25;
    Just play with the setting and volume sliders. If you want, you can pause the player completely when navi speaks, with the second command.
    Nov 2007
    North Central PA
    I'll give that a try after work and get back to ya.
  1. Volume problem with RR.
    By Outsider787 in forum Road Runner
    Last Post: 08-01-2007, 02:45 AM
  2. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  3. RR lower volume for GPS Directions
    By UM_Fan in forum Road Runner
    Last Post: 02-28-2006, 11:46 PM
  4. How to set Freedrive directions volume
    By Phythorian in forum Road Runner
    Last Post: 07-28-2005, 06:35 AM
  5. Mute - Unmutes when reducing volume
    By dan__wright in forum Road Runner
    Last Post: 07-09-2005, 05:58 AM
