Results 1 to 9 of 9
Thread: *** NEW MJS BUILD OF RR *** (Resume Test 3)
    MySQL Error
    Oct 2004
    i need my testers....
    In the effort of continous improvement...
    I have found a few more bugs/issues in RR
    NONE of these where directly reported to me
    I was messing with RR, and discovered a few small things
    plus i wanted some other things
    *** POWER MANAGEMENT - Re-written a bit ***
    (need a tester or two, how has to touch thier screen on resume, to get resume)
    * FIXED - incorrect HD Radio DATA, RDSNAME, was returning incorrect data, it now returns CALL SIGN of HD Radio STATION.
    * FIXED - incorrect HD Radio DATA, RDSTEXT, now returns the stations "Tag line".
    + Added new RR.INI Option: "debugfresh=true/false", this will cause a rename of "debug.txt" to "debug.old" and a new "debug.txt" to be created on EACH RUN (REALLY helpfull, plus no huge debug.txt files anymore).
    + Added new RR.INI Option: "hdvolume=x (x=0-90)", this is the PREAMP volume, dont use this option, unless you need it, it defaults at 75, which i think is optimal. this is not needed to be added in RR.ini, the default is in play.
    SPECIAL: (do not add these to rr.ini, unless needed)
    these two options should not be normally used, I added in a manditory 2 seconds at sleep and resume, the sleep allows the file buffers to flush and events to finish, the resume allows hardware to settle in, specially USB devices.
    + Added new RR.INI Option: "resumedelay=x (x in seconds)", this will add extra time at resume before RR's "resumefromhibernate" procedure runs. (use only if needed, hense OPTION)
    + Added new RR.INI Option: "sleepdelay=x (x in seconds)", this will add extra time at sleep before RR's exits "prepareforhibernation" procedure. (use only if needed, hense OPTION)
    This code is OF COURSE built on 11/7 base, with ALL my previous changes.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I will test whatever you need tested
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    MySQL Error
    Oct 2004
    you know where to find me
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i'm testing this as well.. but felt it good to mention this is NOT a merged .exe like the 9/10 version is so backup your current .exe before testing.
    Live mp3Car Facebook Chat
    MySQL Error
    Oct 2004
    actually sonicx, you're not testing it as of NOW... you know where to find me
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2006
    Will give it a test in the next two days!
    Oct 2007
    OK Mitch tested the resume from ignition is working great and now the GPS indicators in DFX4.0 are working the only problem is still that hibernate and resume from SKIN results in no Sirius. I will email you the debug.txt file
    MySQL Error
    Oct 2004
    Dmistry, no Hibernate signal from your PC in the debug.txt
    what wierd OS u running, i do see a RESUMECRITICAL!
    make sure
    forcehibernate=false
    is in RR.ini
    also i uploaded test 3, to your FTP
    go with that, fixes a possbile double resume, which is FIXED in vista, but can happen on XP, and i run vista so i didnt see it till reading a debug.txt from sonicx and doing research on MSDN
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2007
    will be testing version 3 at lunch today for you and emailing you a new debug.txt file.
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 07-04-2011, 04:28 AM
  2. Resume command throws RR to 100% - All fixed
    By obrienj in forum RR Bug Tracker
    Last Post: 08-25-2008, 09:37 PM
  3. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 01:38 AM
  4. RR Config.exe and Radioshark error in latest build
    By Firebird2 in forum Road Runner
    Last Post: 09-10-2007, 05:53 PM
  5. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
