Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: 09/23/08 OFFICAL Road Runner Release Update
    MySQL Error
    Oct 2004
    NEW BUILD... yep im always making it better, i want to thank the newly MARRIED Gunio for the fast merge of my code into the code base
    also thanking, Sonicxtacy for his quick testing...
    also other testers too!
    CHANGE LOG:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    - built in GPSGAS, removed all code related
    - RR.INI; resumecheck is obsolete
    - Remove log of "Sim.WMSGs",  caused messy debug files!
    - Removed all "reminder..." code/labels
    * RRVer corrected to use executable filename
    * Fixed "STATUS" & "HEADING" indicators, they now pull correctly from SKIN PATH
    ! HD Radio Events, cleaned up all code, fixed RDSNAME & RDSTEXT lables
    ! Added PBT_APMRESUMEAUTOMATIC, followed by BroadcastSystemMessage of PBT_APMRESUMESUSPEND
      (this solves the need to "touch" the screen or generate "input" at resume)
    + RR.ini; "debugfresh", is used to cause at run of RR a new FRESH debug.txt, renames to .old
    + RR.ini; "hdvolume", Defaults at 75, but allows user to tweak 0 - 90 is range
    * Cleaned "GetCurrentLocation"
    ! Added protection code to "PrepareForHibernate", added some extra logging, added Manditory 2 second delay for file flush,event flush
      user can add more time with RR.ini; "sleepdelay", defaults at 0
    ! Added protection code to "ResumeFromHibernate", added Maditory 2 second delay for hardware settle in
      user can add more time with RR.ini; "resumedelay", defaults at 0
    ! Added extra logging to "PrepareForHibernate" & "ResumeFromHibernate"
    * Fixed skin commands "HIBERNATE" & "STANDBY"
    RR.ini: PLEASE READ MJS NEW RR.ini Items.txt
    Code:
    Hibernation/resume:
    sleepdelay=								- (time in seconds) adds time to prehibernation, generally there is no need for this, dont use, unless needed
    resumedelay=							- (time in seconds) adds time to resume, this allows usb and other devices to settle after resume.
    														(only use if needed, example:  resumedelay=5    this will add extra 5 seconds, before hw is re-inited)
    HD Radio:
    hdvolume=									- sets the PREAMP level of the hd radio tuner 0 - 90, 75 is defaulted
    EVERYONE who uses HIBERNATION: make sure...
    Code:
    hibernateaware=true
    forcehibernate=false
    There is a small update to HDRadiocomm.dll so if using HD Radio, make sure you install from the installer, and do a full install.
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    good work as always mitch!!!
    keep it up...
    ill test soon very soon.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Congrats Guino (I think)
    Feb 2006
    Thanks Mitch and congrats Guino!
    What is the "required skin" for?
    EDIT: Just tested and resume works fine now! Thanks!
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by wywywywy View Post
    Related to HDRadio, XM, Sirius stuff...
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    Thanks mitch and Guino! Can't wait to try this out!
    With the changes to RR.ini, are we gonna get a new RRConfig? (Blue? =P)
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I only just finished getting the stuff from the 9/10 relesase added/swapped/changed..
    Ya, I'll get to it, just not sure when...not too long though.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Mar 2008
    Hello,
    Just installed this new exe over 12/13/2007 version...
    RR doesn't start giving am error message "Unexpected error; quitting"
    Is this new build too new for me?
    Thanks!
    --max
    MySQL Error
    Oct 2004
    an error like that isnt gonna be usefull... to help you
    no one has seen anything like that...
    if you got hd,xm,sirius make sure u do a full install
    even if u did, and didnt that error shouldnt happen...
    you could try, delete resume.ini, maybe its corrupt
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2008
    I dunno... I don't have hd, xm or sirius. I understand that the error message is not very informative - but that's what happens to my install.
    Here's my situation:
    -- official RR install (2007 release)
    -- DFX skin
    -- All the above works
    -- put the new RR.exe there --> doesn't work
    -- put the old RR.exe back --> all works..
    What the full install does? I actually did the full install but unchecked the hd/xm/sirius since I don't have those and they were marked as optional installs.. maybe that's the culprit..
    Thanks!
    --max
    Quote Originally Posted by mitchjs View Post
    mitch
  1. PhoneControl integration w. Road Runner problem
    By Broendbjerg in forum PhoneControl
    Last Post: 11-05-2007, 12:01 PM
  2. Road Runner and Iguidance v4 locks my computer.
    By kickercivic1 in forum Road Runner
    Last Post: 10-13-2007, 08:49 AM
  3. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  4. Replies: 18
    Last Post: 08-03-2007, 09:02 PM
  5. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 06:00 AM
