Results 1 to 6 of 6
Thread: how to setup Road Runner
    Jun 2008
    Hello,
    is there a manual that can guide me how to install the RR? I installed the RR and i am getting errors. When i try to open the RR program it'll ask me to link the path. I am new to this program and i am not sure what i'm doing.
    i have few questions
    does RR play windows media player?
    does it support map point?
    thank you all for helping.
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    First, have a look at the RR FAQ section. It will help you figure out a lot of problems.
    Second, get a copy of the RR configuration tool.
    RR Config Updated - Blue ZX3
    This will help you setup your paths and settings.
    RoadRunner does not use windows media player, it uses winamp.
    The road is long but we are getting there.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    but to answer your 2 Q?'s
    WMP = no but use's WMP classic for video if set in the rrconfig to Ext. player
    Mappoint = yes but i hear that it only really works with old versions.
    but to get you started . depends on what skin you want to use , but download winamp 2.95 is tryed and tested , skins like mine and DFX, Teknik use winamp 5.35 this is for Visuals mainly.
    find a skin you want to use , most will have a help files or readme in thier folder to help you set it up , some skins have installers like DFX, LSX and MKIII can't say for any others.
    this should get you a bit further
    Jun 2008
    Quote Originally Posted by carputer1 View Post
    thanks alot, i'll give it a try
    Jun 2008
    I am getting this error
    Line-1
    error: unable to execute the extnedal program
    the system cannot find the file specified.
    that doe sthis mean?
    also, evertime when i doubclick Launch roadrunner.exe. it asking me to find the file roadrunner.msi file.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i had this at 1 point ,can't remember why delete rr and reinstall, use the rr installer , then before running rr , dl'ed mitch's new rr.exe, and install then a skin, and dl'ed blue's rrconfig . make somesetting changes like the the winamp path ,skinpath,music path.
    then run rr
    rr installer = from this thread
    rr.exe = from this thread
    RRconfig = from this thread
    winamp = from here
    oh i 1 last thing that needs to be changed is the folder name for road Runner , the installer will install to RoadRunner not Road Runner, make sure there is a space between the name , as most skins will work with Road Runner not RoadRunner.
  1. HD Radio + Latest Road Runner not working for me
    By BlackStealth in forum Road Runner
    Last Post: 09-28-2008, 02:00 PM
  2. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 06:00 AM
  3. road runner freezing on startup :(
    By skiman in forum Road Runner
    Last Post: 03-13-2007, 10:37 AM
  4. Road Runner Resolution setting
    By JohnWPB in forum Road Runner
    Last Post: 03-01-2007, 11:02 AM
  5. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
