Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 110
Thread: New OFFICIAL Road Runner Installer
  1. #91
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by hollow View Post
    any one else having trouble running skins in full screen after using this installer ??
    screens will not run any different than 800x480
    my screen doesnt support that resolution all i can use is 800x600 or 640x480
    but both display incorrectly
    doesnt matter what resolution i set in rr config . it wont change
    What specific skin(s) are you using?
  2. #92
    Low Bitrate csurfer's Avatar
    Oct 2007
    Edit the screen size in the general.ini file to what you require. It should work.
    If you can dream it you can build it ( I think )
    Build File
  3. #93
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Just did a fresh install of Tiny XP Rev 09 on a system, and then ran the new installer and everything works perfect, Right out of the box! Really nice job on the installer, I used it to install winamp and DOTNET also and everthing worked nice.
  4. #94
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    I put the release notes on the RR Wiki, I could only find info back to the 9/23/08 release so that is all I put up there. If there are any older ones that might be useful I can put those up too if someone knows where they are...
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
  5. #95
    Apr 2006
    Sydney, Australia
    Great work m8! Needed to do a fresh install
    Constant Bitrate IonDokk's Avatar
    Michigan
    Cool Thanks Mitch...
    Just did a fresh install of rr on fresh xp, and must say after some six years on this forum it went as flawless as a frodo install, As for all of the negativity going on in this thread, I can only say after reading it all that everyone here really cares about one thing in the end.
    A free front end that works...
    Thanks to everyone here that contributed because I am only a car audio installer with no programing experience...
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
  7. #97
    Michigan
    Cool
    I did find one thing that i'm sure that i have read somewhere but after 2 days of searching I can't seem to find... when i touch off the xm button it dosen't even try to open xm. I am sure it's in the settings some where, com port is set but i'm not sure about the settings in line 4 in the new coinfig. and I remember reading something about reg dll files or something? any help would be appreciated
  8. #98
    Jun 2007
    There's an option in the installer to install the XM-Sirius-HD Radio files or not. If you unchecked that box then you don't have the dlls.
  9. #99
    Michigan
    Cool Xm Dll's
    1. Where would i look to see where they are if i neglected to install them???
    2. do I need to reinstall RR to get them in or is there an alternative way???
    Thanx
  10. #100
    Jun 2007
    1. That's a mitch question.
    2. You can grab the 10/13/08 Build from the other sticky thread and run that.
    Another thing, does your XM work outside of RR?
  1. My comprehensive guide to Road Runner and Flash
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-09-2010, 06:04 PM
  2. Road Runner Installer and Updater (** Out Dated **)
    By W3bMa5t3r in forum Road Runner
    Last Post: 10-11-2008, 10:19 PM
  3. 09/10/08 TAKE 2 OFFICIAL MJS Road Runner Release
    By mitchjs in forum Road Runner
    Last Post: 09-23-2008, 05:54 AM
  4. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
  5. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
