Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 110
Thread: New OFFICIAL Road Runner Installer
  1. #61
    Oct 2008
    Warner Robins, GA
    I don't know what all the drama is about but I the installer was a really good thing for me especially being new to this car pc thing. I installed it and it seems to be working fine now with CPU usage averaging between 19-26%. before it was 78-100% and always locking up and I had no idea why. So thanks a lot for this installer!
  2. #62
    Nov 2004
    St Louis
    The reason I want to know what every step the installer is doing is because I have so much customization of my system I want to know what is getting changed. For example, you say if I install the Carwings it also installs the Movietimes and RRCam. O.K. that's a start, but where are they installed and what versions. Do I need to delete my old folders cause its now in the \Road Runner\Plugins directory that I'm not currently using?
    I found nowhere in this thread any statement that the skin commands.txt was or was not updated. Is there one? I like writing my own RRCode as much as the next person, but lately only a select few know what the new commands/labels/variables are. Maybe, I too, could benefit from knowing what new functions are now available in the source. Guino and I took a month back in early 06 to layout all the changes and additions to the source from its inception and it had been maintained till he moved. Then there was the source code wars and everything fell apart. Now that the source has once again been melded into one, we need a new skin commands.txt with all the info necessary to use all aspects of the current source. I am stating to feel like Enforcer and Valheru, since I'm not in the select few, I just have to take what I'm given.
    I don't know if you saw my other thread on changing labels based on active audio source, but Chuck, JohnWPB, and I were working on code that set certain parameters based on the current audio source. Guino and I talked about getting this updated and into the source a long,long time ago but nothing ever came of it. He and Nomader discussed skin specific commands in EXECTBL.INI, but never elaborated on actual usage. And now with so many audio sources available, I guess it will never be totally integrated, but something as simple as blanking TAGALBUM when FM or Internet Radio is active should be simple. Or changing TAGALBUM to XMSTATION when XM is the active source or SRSTATION when Sirius is active.
  3. #63
    MySQL Error
    Oct 2004
    Gizmoq, its a inno installer, try googling inno setup log
    there is plenty of documentation, look in the documentation folder
    i have no idea what the directory "road runner\plugins" is its not mine
    why dont u install and see what happens, its so easy
    rename ur existing RR install dir, and install this... its not that hard
    feel free to make a new skin commands.txt, its one thing to say we need it, but its more important that someone does it...
    every NEW skin command, label, var and such are documented, in the documentation directory (if i didnt miss any)
    and if u dont want to use ACTIVESOURCEID, dont, its just a user var
    take a look at carwings, menu.skin
    your asking too much, your welcome to help me at any time...
    but the good news is im basicly done
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #64
    Dec 2007
    xp sp3 directx9, i know it should work cuz it worked before.. i removed whatever RR(ur version also) i had and installed this... So, i have no clue why ilist is not working.. I am the only one having this problem?
  5. #65
    Jun 2008
    Atlanta, GA
    Quote Originally Posted by brandensin View Post
    Do you have iLists turned on in RRConfig?
  6. #66
    Dec 2007
    yes.. it's checked... tried both... no difference...
    code is there too..
    IL,PL,transparent.bmp,sel.bmp,end.bmp,0,50,60
  7. #67
    Dec 2007
    my bad....
    Error on InitDX: -2147024770 Automation error
    The specified module could not be found.
    so, dx problem... dunno why dx got corrupted or removed..
  8. #68
    MySQL Error
    Oct 2004
    bandensin,
    its a DirectX issue most likey
    can i ask a stupid question, spamminator, what the heck is "iLists turned on in RRconfig"?
    if i asked what is "hdport=" set to, i could find that, i dont see anything called "ilists="
    brandensin, what is "checked"?
    how about look in rr.ini for
    usedx=true
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #69
    MySQL Error
    Oct 2004
    brandensin, you missing DX7
    look for
    dx7vb.dll
    in windows system32
    is it there?
    cmd prompt
    c:\windows\system32
    regsvr32 dx7vb.dll
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #70
    Nov 2004
    St Louis
    I googled, I learned about inno, I searched my temp directories, I can't find a "setup.log."
    This is the first I've heard of the documentation directory. Based on this directory, it is inferred that nothing has changed between 12/06/07 and your 09/23/08 build, but we all know better. So I still don't know what the new features are and without that knowledge I can't write a new skin commands.txt. I'd be more than willing to do it, but I don't have the sources from the two dates mentioned above to know what's changed and I don't know VB6 programming so even if I did I wouldn't know where to start.
    ACTIVESOURCEID sounds like just the standardization and internal RR Variable we were looking for.
    I'm always asking too much, if I don't who will. Its just my nature. When I see things needing fixing and don't know how to do it myself, I seek out the prominent expert, make a suggestion, and hope for the best. Unfortunately, when it comes to RR, I'm mostly ignored or the thread dies. At least you respond before you ignore me.
  1. My comprehensive guide to Road Runner and Flash
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-09-2010, 06:04 PM
  2. Road Runner Installer and Updater (** Out Dated **)
    By W3bMa5t3r in forum Road Runner
    Last Post: 10-11-2008, 10:19 PM
  3. 09/10/08 TAKE 2 OFFICIAL MJS Road Runner Release
    By mitchjs in forum Road Runner
    Last Post: 09-23-2008, 05:54 AM
  4. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
  5. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
