New OFFICIAL Road Runner Installer
:drum:
Here it is!
BEFORE DOWNLOADING/INSTALLING PLEASE READ THIS ENTIRE POST
UPDATED - 10/11/08 7:31pm EST
17.6mb
Download from MediaFire
Download from Datafilehost.com
Download from Rapidshare.com
Download from zShare.net
This is the most complete installer I could make at this time.
I would like to THANK a bunch of people:
(If I forgot you, jump in and thank yourself)
Fixerofallthings for work on the Carwings-v2 Skin
Blk02si for Carwings Skin and his support and testing
Blue ZX3 for his RRConfig and SkinTool and other advice
JohnWPB for his advice and testing and SkinTool
Sonicxtacy02 for his MovieTimes and testing and support
IHN for use of RRCAM
and GUINO who took all my work, and got it into the offical build
no matter how much I bugged you :)
Before Install disable your Anti-Virius software, the "RoadRunner.exe" will need to be added as an exclusion. Once you add the "RoadRunner.exe" as an exclusion, you may enable your Anti-Virius software.There is NO Virius/Trojan in this file, and please no one blame UPX. Its because of the use of advanced Operating System API Calls that the AV software "thinks" there is something to be worried about.
NOTES:
1. This installer is existing setting safe, it will not overwrite .ini files.
(you should back them up anyway, who knows when the HD will fail)
2. All required DLLS are automaticly registered.
3. There is many options within the setup to install/not install components.
4. There is an option to Download Winamp v2.95.
The files in this installer are the NEWEST versions as of 10/11/08.
The RoadRunner.exe is built on 10/10/08 (Details later on minor changes)
Please keep any reply posts in this thread ON TOPIC to the installer
like a possiblity that I forgot a file.
I will POST the RoadRunner.exe updates in another thread.
(I need someone to offically put this on the RoadRunner Wiki)
Thanks everyone!
I hope you all get much out of this, as I had fun putting it together
Remember I dont have a carpc, I dont use RR on a daily basis.
INSTALLER HISTORY:
10/12/08
- Removed Weather icons that should not be in this installer
* Fixed default rr.ini to have fastmode=-1
10/12/08
+ Added Shortcut options for Skintool, Skin Editor, RRConfig
+ Includes the NEW RRConfig (fixes fastmode=x)
+ Added startmenu items
10/11/08
+ Initial post
