Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 110
Thread: New OFFICIAL Road Runner Installer
    MySQL Error
    Oct 2004
    Arrow New OFFICIAL Road Runner Installer
    Here it is!
    BEFORE DOWNLOADING/INSTALLING PLEASE READ THIS ENTIRE POST
    UPDATED - 10/11/08 7:31pm EST
    17.6mb
    Download from MediaFire
    Download from Datafilehost.com
    Download from Rapidshare.com
    Download from zShare.net
    This is the most complete installer I could make at this time.
    I would like to THANK a bunch of people:
    (If I forgot you, jump in and thank yourself)
    Fixerofallthings for work on the Carwings-v2 Skin
    Blk02si for Carwings Skin and his support and testing
    Blue ZX3 for his RRConfig and SkinTool and other advice
    JohnWPB for his advice and testing and SkinTool
    Sonicxtacy02 for his MovieTimes and testing and support
    IHN for use of RRCAM
    and GUINO who took all my work, and got it into the offical build
    no matter how much I bugged you
    Before Install disable your Anti-Virius software, the "RoadRunner.exe" will need to be added as an exclusion. Once you add the "RoadRunner.exe" as an exclusion, you may enable your Anti-Virius software.There is NO Virius/Trojan in this file, and please no one blame UPX. Its because of the use of advanced Operating System API Calls that the AV software "thinks" there is something to be worried about.
    NOTES:
    1. This installer is existing setting safe, it will not overwrite .ini files.
    (you should back them up anyway, who knows when the HD will fail)
    2. All required DLLS are automaticly registered.
    3. There is many options within the setup to install/not install components.
    4. There is an option to Download Winamp v2.95.
    The files in this installer are the NEWEST versions as of 10/11/08.
    The RoadRunner.exe is built on 10/10/08 (Details later on minor changes)
    Please keep any reply posts in this thread ON TOPIC to the installer
    like a possiblity that I forgot a file.
    I will POST the RoadRunner.exe updates in another thread.
    (I need someone to offically put this on the RoadRunner Wiki)
    Thanks everyone!
    I hope you all get much out of this, as I had fun putting it together
    Remember I dont have a carpc, I dont use RR on a daily basis.
    INSTALLER HISTORY:
    10/12/08
    - Removed Weather icons that should not be in this installer
    * Fixed default rr.ini to have fastmode=-1
    10/12/08
    + Added Shortcut options for Skintool, Skin Editor, RRConfig
    + Includes the NEW RRConfig (fixes fastmode=x)
    + Added startmenu items
    10/11/08
    + Initial post
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    999 is the magical number!
    Thanks for this, can't wait to try it out.
    Tidder
    Try RevFE
    Jun 2008
    Atlanta, GA
    Awesome Mitch! Thanks to you and all those who helped!
    Just did a clean install, and once I got all my old .ini settings ported over, it seems to working like a dream. Finds the HDRadio, plays music and video, GPS works...
    I think a nice addition would be the option to "fix flash" during the install, as that seems to be one of the bigger issues with new installs. Also maybe downloading a codec pack for MPC.
    MySQL Error
    Oct 2004
    spamminator, what is "fix flash"
    I dont want to get involved with codecs, i wasnt comfortable with putting MPC in it as it is...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    nice installer mitch , what about adding shortcuts for skin editor and rrconfig to desktop as well, you have skin tool and rr there,
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Works like a charm. Great work Mitch.
    It should help the newbies get up and running a little easier.
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    i hate to be the "problem child" here ... but ran this to cleam install in "d:\car\roadrunner\" and rr will not run looks like GDI+ issue. Black/pink line down center of screen.
    car pc is vanilla xp/sp2 with .NET2 installed, but no xp updates installed.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
    Jun 2007
    I noticed the same problem. You have to add fastmode=-1 to your rr.ini. But when you run rrconfig again it deletes the line out of rr.ini.
    Edit: add fastmode=-1 to the ini variables in rrconfig
    Jun 2008
    Atlanta, GA
    I had the same problem with the Fastmode variable in rr.ini
    Fix flash:
    http://www.mp3car.com/vbulletin/rr-f...und-logos.html
    I guess since the use of Flash depends on the skin you use, maybe it should be up to the skin to provide the means to fix it. I'm not sure if Carwings uses flash by default...
    One thing I noticed with MPC, it embeds fine for videos, but when I try and play a DVD it no longer embeds properly, just stretches the whole MPC window (controls and all) to whatever aspect ratio I choose. Would this be a skin or RR issue?
    Edit: Also, you should add the option to launch a readme or FAQ file once the install is done. Better yet, make it mandatory...
    MySQL Error
    Oct 2004
    spamminator, i dont have a good readme/faq... someone make one
    as for dvd, maybe its some .ini setting... ive never seen in used for dvd in anything i do
    machinehead, i will check if fastmode, is being dropped out
    yep it is, we'll get that fixed
    fastmode=-1 means use GDI+ which "pink" regions would be removed
    not what i would think it to be, remember i know little to nothing about RR
    It has been fixed in the NEW rrconfig.exe
    I will update
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. My comprehensive guide to Road Runner and Flash
    By Sonicxtacy02 in forum RR Skins
    Last Post: 02-09-2010, 07:04 PM
  2. Road Runner Installer and Updater (** Out Dated **)
    By W3bMa5t3r in forum Road Runner
    Last Post: 10-11-2008, 11:19 PM
  3. 09/10/08 TAKE 2 OFFICIAL MJS Road Runner Release
    By mitchjs in forum Road Runner
    Last Post: 09-23-2008, 06:54 AM
  4. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  5. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
