Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: What to use for video without dropping music playlist?
  1. #11
    Jul 2009
    B.C., Canada
    That's the thing, I'm trying to use MPC for DVD and video files.
    I'm sure my RRConfig is setup already, this is what it looks like:
    Did I miss something?
  2. #12
    MySQL Error
    Oct 2004
    looks good... u know to play dvd, the skin command is "DVD"
    to play videos its "VIDEO"
    they will both use "video_player.skin" unless u do have a "dvd skin"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    Jul 2009
    B.C., Canada
    I think what's screwing me up is my directory list somehow. This is the progression of my skin
    menu.skin --> video.skin --> a DVD button that plays DVD directly through video_player.skin or a BROWSE button that brings up a directory list of my vidoes as video_browser.skin. When I click play on those videos it opens in Winamp. How do I make it open to video_player.skin when I click on the file?
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you open VIDEO files from the DVD player screen, then all bets are off... there has been no development or testing for this kind of functionality. Similarly, if you open the DVD from the VIDEO player screen, you're on your own..
    If you're on the VIDEO player and want to go DVD player, I would suggest you execute "MAIN||DVD" and if you're on the DVD player and want to go to the VIDEO player, you should execute "MAIN||VIDEO" -- this is so "EXIT" doesn't throw you around from one player back to the other when exiting the screen, but if you don't use "EXIT" (i.e. by exiting with "MAIN") then you can call "DVD" or "VIDEO" directly to switch from one to another...
    Ride Runner RR's Myspace
  5. #15
    Jul 2009
    B.C., Canada
    I'm not sure that's quite the issue because I'm able to play DVDs from the DVD player (button command "DVD" with MPC embedded in "video_player.skin") but when I'm trying to play a video it's from a skin I called "video_browser.skin" with a directory list command (S,xxx,xxx,xxx,xxx..etc) because I want it to list all available videos. When I click on one it opens in Winamp. How do I change what happens when I click on the video in the directory list?
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You MUST execute the VIDEO command so RR switches to VIDEO MODE -- otherwise, if you're not in video mode, the SELECT command (default for folder lists) will think it's a SONG -- that's why you're getting winamp (and loosing your playlist). Before doing anything in video_browser.skin, you should execute VIDEO or you may get unexpected results.
    You can check the current "mode" by reading the ACTIVESOURCE label code.
    You can override the default dbl-click actions in the video browser thru exectbl.ini:
    "SELECT","<MYCOMMAND>",video_browser.skin
    "ONFILECLICK","<MYCOMMAND>",video_browser.skin
  7. #17
    Jul 2009
    B.C., Canada
    Oh, ok. Now I get it, I didn't know there was a video "mode" but it makes sense now that I think back on it. Thanks guino, I'll test it out when I get home from work.
  8. #18
    Jul 2009
    B.C., Canada
    I'm in that stage now where I'm not sure if I should laugh or cry. haha.
    I can get it to switch to the video_player.skin but I can't get it to play. I want it to play automatically, but even the play button doesn't do anything.
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Tical84 View Post
    you may want to post a debug log.. or show the commands you're using and what you're trying to do exactly..
  10. #20
    Jul 2009
    B.C., Canada
    I lost the ability to play DVDs now. It's doing the same thing, going to the DVD screen (video_player.skin) but not playing and that was working earlier. I'm going to clean up my code a bit and see if I can figure out what's going on. I'll get back to you.
    Thanks for your help.
  1. music not indexing - 1.1.0.0
    By collegeboyslive in forum StreetDeck Bug Reports
    Last Post: 12-14-2007, 10:34 AM
  2. Startup Problem with Music Playlist
    Last Post: 11-26-2006, 03:01 AM
  3. Music Synching with M3U/iTunes playlist
    By kappa1281 in forum DigitalMods (Scripts / API)
    Last Post: 01-26-2006, 06:38 PM
  4. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
