Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Only one skin working!
    Oct 2008
    Hi,
    i tried anything I could think of: upgrade Windows XP, upgrade flash, tried different skins, resolutions and so on....
    The only working skin is Carwings-V2. All the others are doing the same thing:
    starting nice, after 2 seconds i get: "pre-loading skin" than I get only a black vertical box (and in DigitalFX_40, a nice woman voice is telling me: System has been locked)
    I will appreciate a little help!
    It looks like this:
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    I had that happen to me too.. I think I fixed it by messing around with the resolution settings either in RRConfig or the skin's data files. I don't remember, it's been a while.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thst because carwings dose'nt use transparence,
    add
    fastmode=-1 to your rr.ini, i think its still getting wiped out by the rrconfig when 1st runned can't be sure. i know mithc did a fix but yet to download to find out,
    Oct 2007
    like CarPuter said set fastmode=-1 in your rr.ini
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I haven't tried the newest build yet, but Mitch says he fixed it.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    yes but on 1st run of the rrconfig i think its getting wiped again but again can't be sure , its just what i noticed when re-building the work comp with the new exec, fastmode worked without running rrconfig then i needed to make soe changes and fastmode disappeared.
    MySQL Error
    Oct 2004
    bluezx3 fixed it in RRConfig, and IS in the downloads in the installer thread
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    its is possiable i know you said it is fixed , i can only asume its the older exe some people are using not your updated 1 ,i'm not saying it is still not working because i can't be sure myself , i'm not going to delete rr just to find out now i have spent this time building a clean system now sorry.
    MySQL Error
    Oct 2004
    carputer1, its NOT a RR.exe issue.. its rrconfig.exe
    download the latest installer, that will give you the new rrconfig
    so that if u run rrconfig again, you dont lose fastmode=-1
    also, be smart, sort ur dir, by file type, and save(archive/backup/copy) all the .ini files
    u can install right on top of existing install, no .inis are over written
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i know you mis understand i'm not saying yes it is the installer , i'm saying some people may still be using the 1st installer you did, yes i know you and blue fixed the second installer i'm just not in the position to try it , to say truthly it is fixed or not. i'm not pointing the finger at either , sorry for the confusion
  1. Replies: 65
    Last Post: 07-23-2008, 03:03 AM
  2. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  3. pink transparency not working if skin is resized by RR
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 02-06-2006, 01:23 AM
  4. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
