Page 7 of 14 FirstFirst 1234567891011121314 LastLast
Results 61 to 70 of 140
Thread: Discussion of Standardization in RoadRunner skins, plugins, addons and whatever else
  1. #61
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well it seems to be going up nicely.
    .:and so does replying to your whinging about my double posting
  2. #62
    Nov 2004
    St Louis
    1st post updated. Saw a post by Guino in another thread. Wonder if anyone's told him about this one, yet?
  3. #63
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Here's my view on the proposals:
    1.a-I've fixed the source to check for the background image file (it it exisits), if the file is not found, it'll try to use a file set in "defaultbg" (variable set in skin.ini), if that does not exist, then it will default to a BLACK background.
    1.b-I've added a presetspath setting which defaults to RoadRunner\Presets\ -- this is where presets will load/be saved by default.
    2-I've added a default backgroundspath variable to RoadRunner\Backgrounds\ -- this is really just so skinners have a default setting when not specified in the INI files
    3-I've added a default pluginspath variable to RoadRunner\Plugins\ -- this is really just so skinners have a default setting when not specified in the INI files. RR won't care where the plugins are, as long as they're properly registered. I LIKE and I'm in FAVOR of setting a STANDARD place for plugins, but I'm not keen of making it a REQUIREMENT.
    4-This really is an agreement between skinnersm, but I do Like this idea, still worth mentioning that users may want to use a specific plugin with only this or that skin.. or may want to NOT use this or that plugin with a specific skin, so it would be nice to see the plugins.
    5-This is a great idea for organization.
    6-I agree and like the idea, I believe plugins could have some defined fields for identification, however, this may need some more discussion as it may require some extra handling from RR itself.
    Ride Runner RR's Myspace
  4. #64
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nice to see ya, Guino!
    #6 I have already been going through all my plugin's and creating a ind that is named same as the plugin. Could also easly add a label with its version.
    I know i asked mitch about one other thing and IDK if he had talked to yet about his current changes.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #65
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by guino View Post
    No need to change anything in RR.
    All a plugin needs to do, and I have started to add to mine (seeing as I made the suggestion), is set <pluginname> indicator to true, then if another plugin wants to know if a plugin is running it uses SDK.GetInd to find out (I assume RR will return indicator codes from extensions or is that the change that would be necessary?)
    Also I like Blues idea of version, I think RRTrafficCams already has a version label of some sorts.
    *Edit, just checked the label is called rrtc_program
    Another edit @Guino, is there a command to tell a custom list to move (highlight) a specific number item in the list?
  6. #66
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    E! shouldn't that be more like rrtc_progver or something?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #67
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Possibly, but that label was in the standalone version (someone requested a program version label, so I added program as the label) and I just ported it over when I did the extension and added rrtc to the front.
    I would suggest <program ID>_version (rrtc_version) would probably be best
  8. #68
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    I'd like to add to #4.
    Skinner's need to add a list of supported plugins that use skins outside of the RR standard skins.
    I'm not sure how the plugin browser will handle that, but this will help users determinine
    which plugins they can use and which they cannot in their current selected skin so they can add it according to their preferrences.
    i.e. RRMedia - I suppose not everyone uses it and might not even skin for it.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  9. #69
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by Sal R. View Post
    the plugin manager(not only a browser no more) will not handle skins at all with the exception of adding the plugin to plugins.txt. After download/installation, a message box will appear telling users they may have to install skins and setup config files for some skins. There's just no other way to feasibly handle .skin file and image copy/pasting/setup.
    Live mp3Car Facebook Chat
  10. #70
    Aug 2006
    Sun Diego
    Quote Originally Posted by Sonicxtacy02 View Post
    I kinda figured that, which why I suggested a list (i.e. PLUGINS_Supported.txt) that can be utilized whether or not a common plugin is useable for the current selected skin.
