Bad HD/memory?
I never had this problem until today... Basically, CPU hitting 2%, but RR's response to my button click is like 7 second delayed.... what in the hell.....
did a fresh reinstall, didn't make any difference... any idea? What in the world though... i didn't do anything.... just started acting really slow suddenly....
Bad HD/memory?
sorry nevermind.. it's not RR.. it's my skin.. all other skin works fine... now i must dig in what the difference is... but why suddenly...
hell... i just don't understand why my skin is having this issue all over sudden... can't find the cause... damn..
ok, problem fixed.. fixed by itself..
for some reason, rr was giving a hell when running 1920x1080 skin...
The more res, the bigger the file, the bigger the file, the longer it takes to load it, the longer it takes to process and display it, thus, a high-res skin would likely require a high-powered machine w/ a fast HD. You can however, scale a skin to a higher resolution without loading too much on Mem/CPU, with a fairly high quality.
Ride Runner RR's Myspace
Thanks for the explanation guino.. I am aware of that, but the problem i was having wasn't just being slow.. It was way beyond that... Been using this for over a month, never had that issue... Funny thing is after several hours, it fixed itself...
" scale a skin to a higher resolution without loading too much on Mem/CPU, with a fairly high quality."
Do you mean like running actual images physically sized at 1920x1020? If so, I am already doing it... Try to expand RR usage as I wanna use it for HTPC![]()
