Results 1 to 7 of 7
Thread: iGo closes when closing screen
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    I'm having a problem with iGo in RR. It embeds fine but every time I exit the gps screen it closes. I'm using the built in gps module set to external in the config.
    Feb 2008
    Ireland
    What is the skin command on the exit button? EXIT or CLOSE?
    Should be EXIT.
    Aug 2007
    SF
    It is set to EXIT. The only way I found to fix this is turn off close applications when exiting RR but now if I close RR all embedded apps are still running but hidden.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Sounds like a bug.
    Turn on close apps and debug.
    Perform the function you are talking about.
    Close RR and post up the debug.txt file so we can see what's going on.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I would also suggest using either "ESC" or "CANCEL", will take you back to the previous screen.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I would also use ESC to exit the iGo screen.
    You can also put the name of the app in the rr.ini like this:
    embedapplist=iGuidance
    This tells RR, in this case, not to close iGuidance on a skin reload, and forces it to remain open. Many skins use the reload skin command when changing fonts, background colors and a number of other things, and can cause embedded apps to close.
    My Fiero Build Thread
    Aug 2007
    SF
    Thanks a lot, switching to ESC worked perfectly.
  1. Replies: 14
    Last Post: 09-11-2008, 04:14 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  3. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 05:31 AM
  4. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
  5. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
