Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: RR does not intercept shutdown - Resume not working
  1. #11
    MySQL Error
    Oct 2004
    bikeboy24, is the playlist file allowed to write?
    winamp.m3u
    in the winamp dir
    a -1, is being written, if winamp cant supply the playlist position
    the problem your having is prob unique to ur setup... so you will prob end up
    solving it yourself
    its prob a HORM issue
    and i have NEVER seen a EWF/HORM setup
    good luck!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    May 2005
    Toronto, ON
    Yes, winamp is in the unprotected drive. I've also installed 2.95 so that it does not save the winamp.m3u file in the protected drive.
    I can turn off HORM and EWF, and I'd still have the same issue with shutting down and resuming.
  3. #13
    MySQL Error
    Oct 2004
    so, add some songs to playlist
    and look at the contents of winamp.m3u
    then go into another source, like sat, or radio
    then back to menu, then exit program
    look at the resume.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #14
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by guino View Post
    however, there's a "SAVERESUME" command you can use for saving resume.ini at request (before turning it off).
    The trick with this is how do you script this to run automatically when the shutdown command it sent via the power button. I'm not aware of a way to get windows to run a script or command prior to shutdown.
  5. #15
    Jun 2007
    I have an idea that I'm going to explore. I think it's possible to use hibernate trigger to intercept the shutdown processes and run a script to properly close RR and then shut the computer down.
    I'll report back once I'd had a chance to play with it.
  6. #16
    Jun 2007
    Update: I found a program that should do the trick. It's called Last Chance, and you can get it here; http://www.fileware.com/public/lchance.exe
    Basically what it does is intercepts the shutdown call and then allows you to run a program, batch file or script before allowing windows to shut down.
    Now I just need to figure out how to write a script to close out Road Runner properly.
  7. #17
    Jan 2007
    Indiana
    Machinehead,
    This should be easy enough in AutoIT. I did one that sends the RR hibernate command. My system wouldn't shutdown and come back properly from within Windows, only from within RR.
    I'll send code when I get home.
  8. #18
    Jun 2007
    I would appreciate that code. Thanks
  9. #19
    Jan 2007
    Indiana
    Machinehead,
    This is the AutoIT script that I use. I use ShutControl, so when it detects the power is cut from my laptop, it runs the .exe and Hibernates properly from within RR.
    Code:
    ;create SDK for COM with RR.  This must be done ONLY once per script
    $rr = ObjCreate("RoadRunner.SDK")
    ;replace COMMAND with your RR command
    $rr.execute("HIBERNATE")
    Save it as an .exe using AutoIT, then call that .exe with your newly found program, and you should be good to go.
    Note: I wasn't the original writer of that code, it was someone else on the boards, I just can't remember who.
  10. #20
    Jun 2007
    That works like a charm, thank you.
    For anyone else, change HIBERNATE to EXIT. Done and done.
  1. New RR Version - GPS Not Working
    By mnetwork in forum Road Runner
    Last Post: 12-28-2007, 10:56 AM
  2. Set RR resolution on resume from hibernation?
    By htsource in forum Road Runner
    Last Post: 08-08-2007, 04:05 PM
  3. Phoco not working in RR Win 2000, help...
    By couteau in forum Road Runner
    Last Post: 09-06-2005, 10:04 PM
  4. ME to resume mp3 upon shutdown
    By Kamakazie2 in forum Media Engine
    Last Post: 11-28-2004, 03:20 PM
