Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: roadrunner with one voice?
  1. #11
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    That program is pretty cool However it does not seem to practical for RR control.
    The bottom line, is just being able to say "Play Artist The Doors" and have RR then play all music by The Doors.
    I have researched this for literally months now, and have not come up with a solution. Anything that is out there is designed to work with iTunes or with WMP, as it is based on their libraries of music.
    This is something that I think is going to have to be put together from scratch for the most part to work with Road Runner. Blue's RMMediaDB can export the list of music in your collection, and I can easily parse that to get artists, songs ect. From there it is creating a Voice Recognition app that can listen to something in your library being requested, and then carry out the command to send to Road Runner.
    My Fiero Build Thread
  2. #12
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    So John are we expecting that RR will work with WMP
    That actually will be gr8..
    Can do do some thing about it
    Thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  3. #13
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    John,
    Can you direct me to the commands to save all songs to a file?
    "RM_Songs" ? .....
    I have a Voice Command Plugin idea for RMMediaDB.
    No grammer file needed. Dynamic....
    ...JJG
  4. #14
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Wow! That would be great! I have tried in the past over and over and over to come up with a solution to mimic the Ford Sync capabilities.
    As for the RRMedia path dump, check with BlueZX3. I just ran the one I had here, and it just exports each album, and not the full path to the songs ect. I know he has a copy of one that does, I just can't find it here
  5. #15
    Dec 2007
    Washington, USA
    RR Voice Control
    Dude!
    Have I got a suprise for RR users! I have a ton coded up now, running 24/7, no memory issues.
    Here is what it does so far.
    Can do any command that can be exec'ed.
    Uses ini for all commands matched to flat text file.
    Each skin can use its own text file for commands or use master file.
    Each text file is loaded dynamically into memory. This narrows command match and is extremely fast.
    So, when you say, Computer Select Audio, it goes to your Audio Skin and loads a skin specific command set. If no command set is configured it stays with the master one.
    Like when you say Set Volume Twenty, no command set change is needed, just the command SETVOL;Master;20
    Configurable preCommand. Computer or whatever.
    Standalone exe using sendmessage. Hides in tray
    Easy ini and text file command loading.
    Just load RR and SkinTool and run through menus picking commands and choosing own phrases to match on. Paste or type in, Click add and go.
    I'm using SAPI 5.1 and the recognition is very good.
    Using small command sets really speeds it up and improves accuracy.
    Might just size it for embedding. Just have to code the Twips to Pixel bit.
    I am now on the mic mute control, although I have had the volume way up and it still matches commands.
    Shoot me some feedback on other stuff to add, ideas, ect...
    I'm stoked, cause like everyone else, I want this, and there has been no follow through on Voice Control for RR and I think it is needed.
    I looked at all of the existing and nothing works correctly.
    I have approached this with the idea of fully configurable command sets, user choices, and ease of use.
    You are not going to "set up RR" by voice control while driving.
    You only want the usable functions of RR and your skin of choice to voice command. Keeping it tight with only the commands you want in each skin, will let you remember the commands to say easier.
    Here's a pic of it what I have right now.
    Cheers
    ...JJG
  6. #16
    Jan 2009
    Great Job!! Keeping my eye on this one.
  7. #17
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I am also watching this one! I am in the hopes that the .ini file you refere to can handle the song list exported by RMedia DB.
    I would love to be able to dynamically play music, and not have to have a command for each and every artist ect.
  8. #18
    Oct 2005
    Nice job! I've been waiting for something like this in a long time!!
  9. #19
    Dec 2007
    Washington, USA
    Well, the way I envision Music is hierarcal command sets.
    Every command set file has a main Menu command and a back one command. Also whatever volume, mute, etc...
    You have a main Music command set that has every album in it , and each Album command has a command set with all the Songs listed from that album only.
    That keeps recognition tight and fast.
    I'm messin with it now and it is flawless on recognition with a crappy mic, TV on behind me, and mp3's goin. I can up the volume to SETVOL;Master;80 and it will recognize any command in the command set loaded.
    I will work on automating the music command sets from Blues On-The-Fly Playlist.m3u. Or I will bother him for his RRMedia path dump.
    The neat thing about this, is once you are done with command sets you are ready to play.
    I'm kinda stumped on a direct command to play a single song.
    Is there a Play;path\song command?
    I will have something for you guys to play with around this weekend.
    I gotta get some sleep for work tomorrow.
    ...JJG
  10. #20
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, here is what I have been thinking for some time, and trying to figure out.
    This command will play a single single song in RR:
    LOADLIST;H:\mp3\Billy Joel\An Innocent Man\Billy Joel - Uptown Girl.mp3
    So something like this would take care of the location dynamically:
    LOADLIST;$MUSICPATH$Billy Joel\An Innocent Man\Billy Joel - Uptown Girl.mp3
    Now, for full albums or artists, that is a bit trickier...
    One: If I was to say "Play Artist Billy Joel", there would need to be some logic and search for that and then make the list on the fly.
    Two: A script that can export playlists to each artist folder, and to each album folder. The one in the root artist folder would contain all songs that artist does, and the ones in the sub directory albm folders would have just those albums in each ot the playlists.
    This would make it possible for "Play Aritst Billy Joel" (Grab the artist playlist)
    Also you could then say "Play Album Innocent Man" and would go one level deeper to the album.
    It would be very easy for me to make a script to make these playlists, as well as output an ini with a full list of artists, songs ect.
    I am talking now with Blue, and hopefully can get a record path dump of all songs, then can use that file to create the voice commands from.
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. Roadrunner Master Install Guide for noobs?
    By rock99rock in forum Road Runner
    Last Post: 03-26-2008, 12:36 PM
  3. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-23-2006, 12:12 AM
  4. Replies: 21
    Last Post: 03-07-2006, 11:43 PM
  5. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
