Page 6 of 6 FirstFirst 123456
Results 51 to 52 of 52
Thread: roadrunner with one voice?
  1. #51
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Now that what I'm talking about.. a little poke is all that is needed
    As for being outside... it is to D&#* hot to be outside right now! hahah I wait for winter when its like 72 degrees out to spend time out there
    My Fiero Build Thread
  2. #52
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Quote Originally Posted by JohnWPB View Post
    As one request (A pleas actually) if I may....
    Can you please add an option for a "Push to talk" command. I have been using voice recognition on my home automation system for years, and delved with it in the car as well. No matter how well you try to use "wake Up commands" such as "Computer" ect... If the mic is always on, you will 100% at some time get false recognitions. There is nothing worse that having the TV volume up loud, and having the kitchen lights come on, and the coffee pot as well, because it "Thought" it heard commands to turn them on.
    This was the same thing that happened with the Voice control built into RR, as well as Navi voice. After a short time after release, tons of requests poured in for both to have a button/key to make the computer start listening. This also allows the audio to be muted/paused, giving a far better recognition of what you are saying.
    Have a look at Ford Sync as an example. You would think if there was a way around it, Two of the largest companies on the planet (MS and Ford) would not make you push a button to speak to the system
    Again, this can be an option in the program. Toggle it on to require a key/button, or off to always have the mic on.
    Hi John
    Can you pls help me out as how do i go about adding a PTT switch to ""Wake"" up the mic...
    I can add as switch ok but .... from here where do i go ( i mean how does it connect to the Mic )
    Thankx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 08:29 AM
  2. Roadrunner Master Install Guide for noobs?
    By rock99rock in forum Road Runner
    Last Post: 03-26-2008, 11:36 AM
  3. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-22-2006, 11:12 PM
  4. Replies: 21
    Last Post: 03-07-2006, 10:43 PM
  5. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
