Results 1 to 8 of 8
Thread: Road runner and Navigator problem?!
    May 2007
    I'm having one problem with this newest version RR. When i press Navi it loads Navigator and docks it, Which is fine. But when i go into another section and then back into Navi it will load a second instance of Navigator and so on for however many times i go back and forth.
    I'm clearly missing something quite simple? i didnt have this problem before installing the newest version of RR. does anybody know how to stop it loading navigator over and over...
    May 2007
    nobody had this problem of road runner opening a program over and over?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Considering over 95% of the community uses either iGuidance or Garmin, probably not.
    May 2007
    ....mmm maybe i'll swap to one of those then! lol
    but that said, i do find it strange as it worked fine for a few years, until i upgraded RR to the latest version.
    Jun 2007
    If you like it though, I understand those frustrations.
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    If it re-opens your app, then your app is not embedding. It may look like it is since it is sized and positioned correctly, but it is not captured in RR. If it was it should not open twice.
    -InfinitiPC
    Newbie Tumeski's Avatar
    Nov 2006
    Pieksämäki, Finland
    Okay i have attempted to embbed iGO8 with bad luck :/ I finally finished all the configs and its all good now, just need to be careful while using it cause the old one stays running under
    If someone could point the way correctly how can i just make it so that it doesnt launch new session everytime i goto "GPS"
    Thanks!
    Nov 2006
    Pieksämäki, Finland
    Aaah! Forget about that, ill make a packet for iGO8... The skin with README file what to edit etc...
    Just tought that someone might alrdy done this...
