bumping this cause I'm curious as well. The speed att. seems like a nice feature (haven't tried it, but may)
I don't know if anyone else is having the same problem but I can't turn on Speed att. and have winamp pause when iGuidance speaks. I found the problem which is that the speed att. changes the wave instead of the master line. However, for the iGuidance speech recognition to work, you have to keep the wave at a certain level.
Anyone got an idea of how I can fix this?
I use this in the ExecTBL.ini file
Code:/,2----------------------FIX for igauto pause---------------------------------------------------------------------------------------------------------------------- "IGPAUSE","SETVARBYCODE;CURRENTSTATUS;STATUS||EVAL;NOPAUSE;strcomp("$CURRENTSTATUS$";"PLAY")||BYVAR;NOPAUSE;<<PAUSE||BYIND;LINEMUTE;MUTE;LINE IN<<||BYIND;AUXMUTE;MUTE;AUX VOLUME<<" "IGRESUME","BYVAR;NOPAUSE;<<PLAY||BYIND;LINEMUTE;<<MUTE;LINE IN||BYIND;AUXMUTE;<<MUTE;AUX VOLUME"
Try setting the iG volume one notch down from full.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
My problem is not iGuidance, I am able to lower the colume when iGuidance speaks. The problem is that if I use the speed att module, it alters the wave volume which screws up everything. For now, I just disabled it and everything works. But I have ot manually increase the volume when I'm on the highway![]()
you have your rr master vol mapped to the wave line dont you?? Ya, I think so...and that would be your problem.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
1.9in x 2.9in -- 47mm x 73mm
Very interesting indeed! I'll check it out tonight and get back to you guys. Thx a bunch!
It was set to "All Lines". I changed it to Master and it seems to have done the trick! I'll know for sure tomorrow when I take it on the road. Thanks a bunch guys!
