Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 130
Thread: RR 11-15-08 ... New Version & News
  1. #91
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Is download possible ????
    Quote Originally Posted by quickmic View Post
    Hmm... Is this not a antilogy? On one side you say the sources are still available (however this is realized), on the other side you make some kind of "copy protection".
    If I have access to the full sourcecode, I could easiely remove the protection and compile it again.
    And if you say, it's allowed to me to make some version public (with the conditions in modRoadrunner listed)........you know that I mean.
    To make it more clear. I haven't the intention to do a "hack" of the version, but in the past I have published some special-modified versions of rr.
    For example. I use for me and some friends a special version of rr with "audiogenie.dll", cause there it is possibility to readout the covers from TAGID directly (and much more features). If offered you (1 or 2 years ago) this version, but you don't want to implement this cause of the used dll.... No problem for me, I created my own version.
    For now I have not access to the fully code (as I think), so it will be much more work to implement your published "parts" of the code.
    But I will see....
    Is it possible to download your version with audoigenie compatibility .
    If yes , do you have a link ?
    Dec 2007
    kpjuk.. u the man!!!
  3. #93
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by hailrazer View Post
    When I Hibernate and resume, it can't find the XM Radio. I have to shut off the computer and restart it to get back XM Radio.
    It's worth the trouble shoot time, the rewritten code is much faster with source switching. Like mitch said, it probably how you have it wired or a setting in rr.ini
    And I still , no matter what I do , can't get iGuidance to find the GPS unless I start iGuidance first and then start Roadrunner.
    That's because RR has built in GPS functionality and RR is stealing the GPS port before iGuidance has a chance to. See RR.ini and/or run xport if you want to split the GPS signal between the two apps.
    And no I am not a Newb when it comes to this stuff. I have every setting just like it was and have tried every trick in the book.
    You could have fooled us! You will probably have to adjust a few settings, as you are jumping a year in development time, many things have changed or been updated in the code, new commands, improvements, etc. Obviously you missed a 'trick' somewhere because it's really not that hard to make RR work.
    I'm done with this build and I'm going back to last years. If this is what I have to look forward to every 4 months..... then thanks but no thanks.
    Sorry that FREE software requires any type of thought or reading to make the most of it.
  4. #94
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I had installed the 12-08-2007 version and everything was working pretty OK.
    I find it interesting that this worked right for you in the 12-8-07 version but not in the new version. This same GPS port functionality existed in the old version as well. So you've set it up before obviously, most likely by setting the GPS port to 0 in Road Runner.
    I wouldn't doubt that there's some user error going on here.
  5. #95
    Nov 2008
    SoCal
    Guino,
    I remember seeing your thread back on the 8 club but I never realized you were the one behind RR.
    I'm preparing to do a carputer and I'll be watching this thread closely.
  6. #96
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Well since I'm the only one who seems to be having problems, I thought I would give it a go again.
    So I uninstalled the older version and installed the newer version.
    No dice it still didn't work right. I was about to give up when I figured I would try the old Windows tricks. So I uninstalled RR again, and then did a file search and manually deleted every RR file I could find. Then I used Regedit and got rid of every registry mention of RR.
    Shut down, restarted and reinstalled. Configured everything and Bam..... It worked perfect and ran everything perfectly even after hibernations.
    So I guess it was "User error", though I don't know why it was my fault.
  7. #97
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by guino View Post
    I don't remember getting your code ? Can you send it again ?
    I already said that I'll put only a reminder on the next versions...
    Guino,
    Just sent you the file to your wb****** hotmail account.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #98
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    If you get board guino and looking to add some new commands, here are some of my suggestions.
    For Internet radio or streaming stuff.
    Code:
    If in audio and status=play and TRACKTIME=00:00 then
    	reloadlist every 7 sec.
    	setvar;autoloadlist;1
    	else
    	stop reloadlist
    	setvar;autoloadlist;0
    End If
    do this on
    tracknumber change
    play
    stop
    A button to manually start and stop it
    “AUTOLOADLIST”,”BYVAR;autoloadlist; reloadlist every 7 sec.<< stop reloadlist”
    And a command
    “ONSCREENCHANGE” to trigger after entering and exiting screens.
    “ONTRACKCHANGE” to trigger when tracknumber changes, good for xm, siruis and Internet radio instead of on “songestart”
    2001 S10 ZR2
    Chucks Skin - to old
  9. #99
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I think that is about the most clearest "Chuck" chunk of code that I have ever laid eyes one..LOL....
    Um...some really familiar about that "ONSCREENCHANGE" cmd.... hummmm...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #100
    Nov 2004
    St Louis
    Quote Originally Posted by Chuck View Post
    Code:
    	else
    	stop reloadlist
    End If
    do this on
    tracknumber change
    play
    stop
    And a command
    That's pretty good and it covers all the issues we found in the Trackname Thread. Hey Chuck are you using the ACTIVESOURCEID code MitchJS incorporated in the 10-13 build? Have you been able to add sources/IDs on your own? I know Mitch mentioned it but no one explained how to use it or how to update/add to it. If you've updated my code using ACTIVESOURCEID, could you post it in the other thread so I can take a look?
    And it VB not RRCode which makes it really scary.
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. What Winamp version is everyone using with RR
    By craigt in forum Road Runner
    Last Post: 09-30-2005, 02:42 PM
  3. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
  4. Any news about my strange problem? RR and Girder
    By slimmegane in forum Road Runner
    Last Post: 07-11-2005, 12:52 PM
  5. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
