What skin are you using? What is the command on the button? There are specific commands for play next nexttrack and so on.
I was driving to work monday and I hit the skip button on RR's music screen. Instead of skipping, it started fast forwarding. I know if you keep pressing the button, it is ment to fast forward. But I just touched it. Is there a way to eliminate the fast forward option for that button?
Could be a TS going south.
That was my first thought.
EDIT: ..and NO, it wasn't my first thought ever - Enforcer, BlueZX3. Thank you!
I hope it's not the TS. I just got it.
I'm using the brushed metal. I don't know how to find the commands. I'll look around and see if I can find anything. Thanks.
Brushed metal just uses Next and Prev as standard.
Could be settings in the TS drivers that simulate a hold on the press.
I'll check the driver. It's weird. It didn't do it on my way home from work last night. And it doesn't do it on the skip backwards button. Also, I just installed a wireless keyboard a week ago. Last night, I turned off my gps and it didn't skip anymore. Maybe some issue with the usb hub. Thanks again.
