Results 1 to 8 of 8
Thread: Problem with Sirius not loading
    May 2005
    Monterey, CA
    Question Problem with Sirius not loading
    I just rebuilt my carpc and loaded the latest if RR and using DigitalFX 4. I got everything working except for Sirius.
    When I hit the Sirius button it doesn't do anything. What can I check to why it doesn't do anything?
    Same goes for gas prices but I assume it isn't using the new command?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Gas prices are available only by plugin now -- check the plugin section. The built-in feature got obsolete and stopped working.
    For Sirius, there was an entire re-write and the new code requires .NET installed along with the libraries it uses. I'd suggest you install it all with the installer and it will install what you need automatically.
    Ride Runner RR's Myspace
    May 2005
    Monterey, CA
    I used the exe installer. Is that what you are talking about? I can run it again, I am not sure if it was before or after the 15th of nov. Seems like it is the newer one.
    Will the one from http://guino.home.insightbb.com/ work?
    May 2005
    Monterey, CA
    Thanks for the help. I ran the update and Sirius worked! I can't go without Sirius. I was having withdrawals.
    As far as the GAS prices i extracted the gap zip from the other post and they still do not work. Is in there something in the skin i have to change or ....
    I extracted the files to the RR folder, I just thought about it, is there a plugin folder or something? I can't remember?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You need to install this plugin for Gas prices:
    http://www.mp3car.com/vbulletin/rr-p...4-09-08-a.html
    May 2005
    Monterey, CA
    Thanks, so in the case of DigitalFX4 do i need to change the button tag?
    Dec 2004
    Miami, FL
    Hey, I have this same problem, but only intermittently. When it happens, I click on the sirius button the home screen, and nothing happens. If I reboot the carputer, that usually fixes it. Any idea what's going on?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
    MySQL Error
    Oct 2004
    just use the installer, it has newest sirius/hd/xm control classes and other new items, like artwork
    (when released)
    using the .exe only zip file, u miss out on a bit of new stuff
    and could cause problems if you use sirius/xm/hd and more
    prob no real good reason NOT to use the installer
    it will not overwrite any existing .ini files!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. Strange Sirius problem
    By dima237 in forum General Hardware Discussion
    Last Post: 11-04-2006, 03:37 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. Sirius Song name problem
    By -zip- in forum Road Runner
    Last Post: 09-13-2005, 10:20 PM
