Results 1 to 10 of 11
Thread: GPS Time
    May 2005
    Monterey, CA
    GPS Time
    When I have GPS time sync enabled it jumps to Feb 08.... Any ideas? Then this causes RR not to run with the new time out. The time is fine, just the date.
    Thanks.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Personally I recommend not using GPS time. It has never worked correctly for me or many others.
    My Fiero Build Thread
    May 2005
    Monterey, CA
    Alright, this is the first time I have had an issue with it. But it doesn't matter windows can sync from the internet anyway.
    Thanks though, at least I am not the only one.
    Newbie thwack's Avatar
    Sep 2005
    Adelaide, SA
    Just started having a issue with this as well. It almost looks like GPS Time has broken with the latest release as I am using international units which have been working for a long time and with all previous releases.
    Now the Day and Month are swapping. My system is set to dd/mm/yyyy and the GPS Time is setting mm/dd/yyyy so today I had it set to 13/4/2008 (I am ahead 9.5hrs so by midday today this will be 12/5/2008). I can confirm that the old versions of Road Runner are working well and that it is not my GPS unit as this is happening with both a u-blox and a Garmin both of which are reporting the correct UTM/UPS time.
    I do not have US date settings set in the ini file.
    I would love for this to be fixed as I do not have an internet connection in the car and have been relying on the GPS Time to set the clock.
    Cheers.
    Thwack
    PS: It seems that the GPS Time set is before the Time Bomb in the current version as I now get the time set to the incorrect date and then Road Runner exits. Pain in the rear end to have to try and set the date then get Road runner working every time.
    Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
    Car- 1988 Nissan Patrol 4WD
    MySQL Error
    Oct 2004
    im looking at gpstime right now
    as far as I know, No code in this area of RR has changed in quite some time
    now, i dont have gps, nor know anything about it
    1st, "gpsusadate" is checked, if true, then the format is changed
    your PC's timezone must be CORRECT!!
    mitch
    what does the
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2005
    Monterey, CA
    I will have to play with it some more, now that I have read all the posts. I did check my timezone and that was set. The time is fine, it is just the date. I will that gpsupdate option, maybe that was my problem. I will you all know.
    FKA psptibby
    Feb 2006
    I tried using GPS time and it didn't work for me either. It always set the date to 2015 (the time was fine). The time zone for my PC is set correctly.
    MySQL Error
    Oct 2004
    maybe u can capture a gpsresponse
    starts with
    $GPRMC
    and paste it here
    example
    $GPRMC,040302.663,A,3939.7,N,10506.6,W,0.27,358.86 ,200804,,*1A
    the date here is, AUG(08), 20th, 2004
    20 08 04 DDMMYY
    if it comes in MMDDYY, then set gpsusadate=true
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2006
    Quote Originally Posted by EricE View Post
    I changed my GPSUSADate to false and now GPS time works fine.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Typically if someone has gpsusadate=false and it doesn't work, changing it to true fixes it.
    Similarly, if someone has gpsusadate=true and it doesn't work, changing it to false fixes it.
    Ride Runner RR's Myspace
