Results 1 to 10 of 19
Thread: ID3 versions, what does RR use?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have nearly 5,000 songs tagged using a Tagrunner. Problem is cetain ones just won't seem to show up in RR. Certain bands typically. I will clear their Id3 tags out completely and use this software that automatically tags them. In RR only the file name seems to show up and no Artist or album info. I have tried to set RR to use all versions. What versions of Id3 1 and 2 can RR see?
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by Dougw133 View Post
    I have nearly 5,000 songs tagged using a Tagrunner. Problem is certain ones just won't seem to show up in RR. Certain bands typically. I will clear their Id3 tags out completely and use this software that automatically tags them. In RR only the file name seems to show up and no Artist or album info. I have tried to set RR to use all versions. What versions of Id3 1 and 2 can RR see?
    Doug, Mine does the same thing and like you, I erased and re-tagged them and even switched between the id3's, no dice. I had been trying to figure that out for a while but no big deal for me, I can live with it. However if their is a solution
    If you cant DODGE em, RAM em.
    Low Bitrate sedtc's Avatar
    Jul 2006
    tally-ho, fl
    what tag settings do you have selected in rrconfig? try using id3v1 tags mixed with id3v2 and check the settings that your tagging software is using. rr does not like the tags with unicode in them, the tags will show up with strange characters in the name (speaking only for some of the older versions of rr).
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    It's also possible that Tagrunner is the problem and isn't creating compliant tags.
    Feb 2007
    Motor City
    Speaking for myself (Sorry Doug not trying to thread-jack) I've tried manually editing the tags when they didn't display correctly in rr and the out come was the same also in my case, the mixed setting is checked in the config.
    Nov 2007
    PA
    Quote Originally Posted by Ramanator View Post
    Exactly my problem too...I have tried manually editing them in windows by clicking properties. Redo it all and it still won't work. This is why I am wondering if sometimes Tagrunner might grab some ID3's from itunes or something and tag them with an incompatible Id3 as Machinehead said above. So I am curious if it's possible even though I try to manually edit them etc... if they might be of an incompatible tag regardless if the song, artists, etc.. is correct. I know there is several kinds of each version, like ID3 V1.2 , V1.3 , V.1.4 and then V2 has it's own separate few.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    try tagscanner.. it is the best out there and it is free
    Jun 2007
    I use a program called Tag&Rename, it isn't free but it does have a free trial period. It does give me tags that work in Road Runner.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I had this problem also with ID3's not showing up in RoadRunner. I download ID3-TagIT 3 and when i opened the program the ones that werent working in RR didnt show the tag information in ID3-TagIT... and usially it would only say there was a version 1 tag or ver 2 tag but not both... it would try to convert the tag versions and edit the tags in the software but it would go back to how it was... Oh yea and all the music came out of itunes...
    I don't know how i came about to finding this but it worked - I opened the folder in windows that had the songs, right clicked on them then clicked properties, then chose the Summary tab. In there (under simple not advanced) if there is anything in the comments box erase it, if there is nothing just click in the box hit backspace once then hit ok... I did this to all my MP3s that werent showing tags right and now they work perfectly... I don't understand it, but it worked for me. Give it a try!
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Just a note:
    If you are manually editing the tags with Media Player, it just changes the tags in the library, and does not write the tag info into the MP3 itself.
    My Fiero Build Thread
  1. Resume command throws RR to 100% - All fixed
    By obrienj in forum RR Bug Tracker
    Last Post: 08-25-2008, 08:37 PM
  2. RR Video Issue.....
    By grnLude in forum Road Runner
    Last Post: 05-20-2008, 12:24 PM
  3. Why do people think RR is hard to setup?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 05-18-2008, 12:38 AM
  4. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 03:14 PM
  5. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
