In this version:
# Added PNG files support for Sirius and XM art
# Added MatrixPC improvements to directory playlist functions
# Added support to Phidgets inputs and outputs
# Added Radio LOADLIST functionality
# Added RELOADSCREEN command
# Added SETGAMMA dynamic command
# Fixed SETVARBYIND command
# Fixed OSK always writing uppercase letters
# Time-Limit changed to a version reminder (after 4 months)
Notes:
-LOADLIST for radio works with .INI files of the same format of radio.ini
Thanks for your support,
Guino.
here is the history file... hopefully i didnt miss anything
Guino added a few new skincommands
impoved Phiget Support
I mostly continued to work on "Dimmer"
I also did more work on Vista Mixer Control, should be complete now
here is the history:
Code:
12/02/08
+ "SETGAMMA" skin command, "SETGAMMA;red;green;blue"
+ "LOADLIST" radio support
+ "RELOADSCREEN" skin command, used when changing skin file live, reloads current .skin file (screen)
+ MatrixPC improvements to directory playlist functions
+ Support to Phidgets inputs and outputs
+ added minimize when video is using builtin or MPC (when u minimize RR, video now does too)
* some code clean up in "Video"
12/01/08
* if using built in video and dimmer at same time, dimmer will be off on the video_player.skin
^ advise - use MPC set its output to VMR9 (windowed) and dimmer will work
+ Vista Mixer Control - Master Balance
* Improved Siriuscomm.dll
11/25/08
* Improved Phigets support, Support for Relays and Indicators
+ Vista Mixer Control - added Logging of discovered Playback Source Lines
+ Safety checks for invalid custom audio slidercodes or volume/mute commands (i.e. "VOL+;bad name")
* Improved iGuidance support
11/23/08
* Vista Mixer Control Support # NEW VERSION # (supersedes Vista Master Volume Control)
requires VistaMixerControl file set
11/20/08
# SETVARBYIND now works properly
11/18/08
* Sirius / Xm Artwork when using GDI+(fastmode=-1) defaults as .png, falls back to .gif
11/15/08
* Vista Master Volume Control Support (very early stages)
* task bar no longer hides during load, if not set in settings to be hidden
+ ONBTNHOLD Event, for every button hold
