yes it is, you can use "BYVAR" with "EVAL" look in the skin commands.txt, you'll see some good examples in there...
I have IbusRR which feeds the current temp called $COOLANTTEMP to RoadRunner. Is there a way to display this on the main screen, let's say beside the Wifi symbol? I know I have to edit the skin file but I'm not sure what exactly to add. Maybe have the font change colors depending on the current temp.
Also, is there a way to pop a warning if the temperature exceeds a certain value?
EDIT: Just figured out how to display it:
L,12,197,206,19,240,240,240,14,"Arial:B","=COOLANT : $COOLANTTEMP$","LEFT"
Now, is there a way to do an IF =...THEN... statement and pop up a message box/warning?
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
For the warning look at BkueZX3's extended RRPlugin.
thanks guys!
