Results 1 to 10 of 20
Thread: How to install a GPS software on the carpc?
    Aug 2008
    hello
    i have this software: IGO 8
    and i want to know how can i install it on my carpc and how to open it in the RR..
    i tried to read this one:
    http://www.mp3car.com/vbulletin/rr-f...ad-runner.html
    and i didn't secced to install it..
    thank you
    Aug 2008
    some one can help me?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Read post #1 and Post #9 on this thread
    Ride Runner RR's Myspace
    Aug 2008
    i didn't understand this line:
    Make sure you run with arguments as follows, either from a shortcut or from your front end
    iGO-MySize.exe -width=640 -height=384
    what should i do in the windows whne i will succed to run it on the windows i will try to run it on the RR...
    so where should i put this line:
    "iGO-MySize.exe -width=640 -height=384"?
    Aug 2008
    should i past this line in the
    "target" of the Shortcut?
    or in the comment? or aby in "start in"?
    when i clicked on the Shortcut it's dosen't open nothing...
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    in rr config under gps , set to external gps
    in path put XXXXXXXXXXX\iGO-MySize.exe -width=640 -height=384
    XXX= path to EXECUTE
    in Name IGO8
    then in your skin file look for the button cmd , where the you want to launch the gps program
    B,xx,xx,xx,xx,"GPS"
    Aug 2008
    "then in your skin file look for the button cmd , where the you want to launch the gps program
    B,xx,xx,xx,xx,"GPS" "
    what should i do with that?
    to open the skintool? what is the
    "B,XX,XX,XX,XX,GPS"?
    how can i open it without the RR?
    when i clicked on the ig mysize.exe nothing happend...
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    the xx's are the numbers for postition and size of the button code, its normally in your menu.skin inside the skin folder, open the skin file in notepad then you can edit it,
    or use the skineditor ( found in the skin section of this forum)
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've updated this thread:
    Please view iGo8 section on the above thread again.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    wow thats changed since i last looked at it , nice move Guino
  1. Replies: 1
    Last Post: 07-31-2008, 06:37 PM
  2. 2001 VW Jetta CarPc Install
    By *Glow* in forum Show off your project
    Last Post: 03-27-2008, 04:00 PM
  3. GPS Woes, ?, after ShowGPS install - Help...
    By kolemieux in forum Road Runner
    Last Post: 08-27-2006, 07:43 PM
  4. How to install GPS???
    By Cue in forum General Hardware Discussion
    Last Post: 07-13-2000, 02:39 AM
