Results 1 to 4 of 4
Thread: Multiple locations for Data???
    Low Bitrate IonDokk's Avatar
    Michigan
    I may have missed something here somewhere but I have tried the below method to add a search for multiple locations for Data. When I do this I can get the video to go back to the root of the original video file by holding the browse button down... But I cannot get it to work for music... (in the Elite lite skin at least)
    Per Guino...
    How do I browse Multiple Locations for Audio and Video ?
    There is a way you can have as many video/audio folders as you wish, anywhere, and in ANY drive/pen drive, external drive etc:
    Here's how I put this together and at the same time made the Audio CD player work too (for both audio tracks and mp3 CDs):
    -A "go home" feature is done by pressing and holding the "BROWSE" button (the one that simple presses lets you view the selected folder). This feature allows you to go to your main "browse" location.
    -You should make a BROWSE.RRL file (which is a simple text file) you create and place in ANY of your folders accessible in RR. The format for this file is basically:
    <FULL DRIVE+PATH>;<DISPLAY TITLE>
    For instance, If I made the following BROWSE.RRL file and placed it at my D:\Music\ folder:
    E:\;>CD<
    F:\;>PEN DRIVE<
    C:\Windows\;Windows Folder
    I used the "<" and ">" characters to simply "call attention".
    When I browse that location on my hard drive (D:\Music\), RR will display those "options" on the very top of the list. If I wish to borwse any of those locations I simply have to click "browse" on any of them.
    Since you can't really switch drives with the "GO BACK" and "BROWSE" functions, you can return to your music/video home (set in RRConfig) by pressing and holding the browse button ("go home" feature) -- which in my case would again show the BROWSE.RRL file and the folder contents.
    You can create as many BROWSE.RRL files as you want, and place as many items you want in them.
    To play Audio CDs, you'll need to add the .CDA extension to your audio files setting in RRConfig (unless it is/was blank).
    The Multiple Browse feature works in ANY folder browser used in RR. Furtheremore, it may even work on the Application Launch list -- if by any means you have some use for it there.
    NOTE: If you have any trouble make sure of this first:
    -Open any "explorer window" (i.e. the folder with the browse.rrl file)
    -Click Tools->Folder Options, then go into the "VIEW" tab
    -Look through the list and make sure that the "hide extensions for known file types" option is DISABLED and click OK.
    -Now make sure your file name is not anything like "browse.rrl.txt" instead of just browse.rrl
    -Also make sure to put the browse.rrl file in a folder that RR can browse onto (i.e. you music folder).
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try the same thing on the BMV2 skin -- if it works, it's skin related.
    Ride Runner RR's Myspace
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    You may want to look into the Media Launch plugin, it will auto detect and upon one click auto load new media when it becomes available - such as inserting a pen drive. It's integrated into shock v6.0 also.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Other options:
    RRFob from RRExtended plugin.
    If you know the location of your additional data, you can use a button with the code "SETPATH;<PATHTOFOLDERWITHDATA>"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. Multiple ECU responses
    By mctodd00 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2008, 08:16 AM
  3. Multiple touchscreens on one PC?
    By jm1133 in forum General Hardware Discussion
    Last Post: 07-02-2008, 03:45 PM
  4. Replies: 0
    Last Post: 03-24-2005, 01:17 PM
  5. Multiple Monitors and Multiple inputs
    By nixneon in forum Newbie
    Last Post: 03-19-2005, 08:30 PM
