after spending over $1000 on the Car PC hardware.. NO
it's still on bench anyways :\ but so far so good, on the PC side.
Well I now have the same MB indoors as the one in the car, the car has a XP-M 2400 and indoors has a XP-M 2500. I now also have identical 80GB 2.5" drives so I will build indoors and test then ghost to other drive and update the car with that one.
So yes I will have a test/Develop machine![]()
I, too, keep a dev machine running at home with an indoor screen, whereas the cars have outdoor screens. Same hardrive, same hardware, same USBs.
I'm a little more of a risk-taker than Fixer: trusted software is installed on the Car as soon as its tested (RR updates, plugin updates, etc); test/beta software is usually only one version behind if installed in car; hardware is always the same although some remains on the Dev machine until software for it matures, i.e., Fusion Brain had to wait for RRFusion.
I will leave some software on the Dev machine waiting for it to mature, otherwise its documented on the dev machine and removed (my memory ain't what it used to be). Hardware thats not implemented is also documented and removed to be sold at swap meets/eBay/used elsewhere.
Dev machine is backed up to my server weekly. Restore points are set before every beta software test. My server is also my repository for all CarPC related software downloads (I probably have 90% of everything RR since its inception). I also keep a notebook listing all the versions of everything installed on the CarPC for issues like RRFusion doesn't work with the latest Fusion drivers, YET, so I have the old drivers on both, but I keep downloading the new (without installing) just to keep the repository current. I share my repository with no one and its inaccessible from the net. In addition, approximately 3 times a year, the downloads/install pkgs for all software on the CarPC is backed up on data DVDs and stored offsite.
I have a quad core vista x64 beast for my devel machine. I do all RR testing on this. If there is something specific to XP I want to test I have a virtual machine of XP SP3 installed so I can test the differences in real time on the same machine. Since I run an embedded OS in the car sometimes the production software is 6 months or more behind the devel box.
Gee Gizmo.... That's just one notch below insanity....![]()
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Sorry to disappoint you. About every 4 month everything I touch breaks so I've learned to keep multiple layers of backups.
And yes, I have two or three of everything cause at several times over the years I've considered doing a stealth install in one or another of my cars - to date: I never have because the convenience of the tablets, IN MY OPINION, still outweighs the OEM look.
I'm using my old MSI CN700 board that could not handle DFX 4.0 - but its not good for a test machine.
I think I'll just convert that to my torrent server since its fanless and powered off a DC brick.
I'll probably pick up the identical hardware I have in my car setup now and build a test machine with that...
