Results 1 to 4 of 4
Thread: Can you add arguments to roadrunner to load a specific skin?
    Apr 2007
    Is it possible to add an argument after the roadrunner.exe shortcut to force it to load a specific skin?
    This would help a lot for bouncing between multiple skins im testing and working on.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you have a resume.ini file, you can change the current skin path in there. If you don't have resume.ini you can change it in RR.INI -- or you can always delete resume.ini, your choice.
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Here is quick and easy way to do this, put the exe in your rr folder and run it instead of rr and it will start rr with choosen skin. It will either edit your resume.ini file if one is found or it will make one before starting rr. You can also specify a skin folder name as a parameter and it will just start rr with that skin instead of giving you a chooser.
    Example "Skin Switcher.exe BMV2", will start RR with the BMV2 skin.
    Side note: Runs "RoadRunner.exe", so if you use something else beside the default name, you will have problems.
    Also includes the source code.
    Have fun and a Merry Hoilday!!
    Attached Files Attached Files
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
  1. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. Load Skin by time of day
    By sonvan in forum RR Skins
    Last Post: 11-09-2007, 10:33 AM
  4. Which is the lightest RoadRunner Skin?
    By EL_GRECO101 in forum Road Runner
    Last Post: 06-20-2007, 02:54 PM
  5. Add QuickMute Button in skin
    By aguiu in forum Map Monkey
    Last Post: 03-23-2005, 07:52 PM
