Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Byvar and LoadIMG problem
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Tanks Sal R for your help .
    I had doing some test with skintool ,
    and if i use that line :
    BYVAR;Testswitch;SETVAR;Testswitch;1<<SETVAR;Tests witch;0
    I have a good issue , but not on the screen !
    I test your second option and you return the result,
  2. #12
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    cool.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  3. #13
    May 2008
    Bordeaux, France
    Quote Originally Posted by Sal R. View Post
    Button:
    "BYVAR;Testswitch1;TESTSWITCHOFF<<TESTSWITCHON "
    ExecTBL
    "TESTSWITCHOFF","SETVAR;Testswitch;1||LoadIMG;18;1 93;137;16;$DisplayIMG1_off$;out"
    "TESTSWITCHON","SETVAR;Testswitch;0||LoadIMG;18;19 3;137;16;$DisplayIMG1_on$;out"
    I have the same issue , don't run on the screen but run out the screen with skintool !
    RoadRunner Skin
    RRScreen F-CNS(800X600STRETCHED)"BROWSER"
    INC,BottomButtons.txt
    TMR,4
    IMG,380,133,55,50,"MenuIcons\voiture.png",OFF
    IMG,380,133,55,50,"MenuIcons\voiture.png",DOWN
    IMG,380,133,55,50,"MenuIcons\voiture.png",ON
    IMG,220,132,55,50,"MenuIcons\bateau.png",OFF
    IMG,220,132,55,50,"MenuIcons\bateau.png",DOWN
    IMG,220,132,55,50,"MenuIcons\bateau.png",ON
    IMG,57,228,55,50,"MenuIcons\garage.png",OFF
    IMG,57,228,55,50,"MenuIcons\garage.png",DOWN
    IMG,57,228,55,50,"MenuIcons\garage.png",ON
    IMG,58,134,55,50,"MenuIcons\maison.png",OFF
    IMG,58,133,55,50,"MenuIcons\maison.png",DOWN
    IMG,58,133,55,50,"MenuIcons\maison.png",ON
    IMG,647,113,128,129,"MenuIcons\maison.png",OUT
    B,640,330,150,52,"SAVETOSKIN;testswitch;1||SETVAR; testswitch;1",
    B,488,331,148,49,"SAVETOSKIN;testswitch;0||SETVAR; testswitch;0",
    L,71,80,357,35,255,255,255,23,ARIAL:B,"=TWELVE COMMAND","SCROLL-CENTER"
    L,650,348,128,19,255,255,255,18,ARIAL:B,"=OFF","CE NTER"
    L,497,348,131,19,255,255,255,18,ARIAL:B,"=ON","CEN TER"
    L,501,166,139,26,255,255,255,16,ARIAL:B,"=LATITUDE :","LEFT"
    L,501,192,139,26,255,255,255,16,ARIAL:B,"= ||GPSLAT","LEFT"
    L,501,111,139,26,255,255,255,16,ARIAL:B,"=LONGITUD E:","LEFT"
    L,501,139,139,26,255,255,255,16,ARIAL:B,"= ||GPSLON","LEFT"
    /Definition visualisation on off des boutons
    L,519,75,246,33,255,255,255,18,ARIAL:B,"=$DisplayT ext1$","SCROLL-CENTER"
    L,17,237,138,33,255,255,255,18,ARIAL:B,"=$DisplayT ext4$","SCROLL-CENTER"
    L,336,144,138,33,255,255,255,18,ARIAL:B,"=$Display Text3$","SCROLL-CENTER"
    L,178,143,138,33,255,255,255,18,ARIAL:B,"=$Display Text2$","SCROLL-CENTER"
    L,17,142,138,33,255,255,255,18,ARIAL:B,"=$DisplayT ext1$","SCROLL-CENTER"
    L,521,285,246,33,255,255,255,18,ARIAL:B,"=$Display Text1$","SCROLL-CENTER"
    /, B, X, Y, W, H, COMMAND;COMMANDCODES, TOOLTIP
    B04,8,216,158,68,"BYVAR;Testswitch4;SETVAR;Testswi tch4;1<<SETVAR;Testswitch4;0",""
    B03,329,123,158,68,"BYVAR;Testswitch3;SETVAR;Tests witch3;1<<SETVAR;Testswitch3;0",""
    B02,168,123,158,68,"BYVAR;Testswitch2;SETVAR;Tests witch2;1<<SETVAR;Testswitch2;0",""
    B01,6,122,158,68,"BYVAR;Testswitch;TESTSWITCHOFF<< TESTSWITCHON",""
    B,300,521,99,80,"PLAY",@STOP||PLAY@
    B,398,521,101,80,"NEXTTRACK",
    B,203,521,99,80,"PREVTRACK",
    B12,596,521,99,80,"VOL+",""
    B11,500,521,99,80,"VOL-",""
    B09,102,521,100,80,"EXIT",""
    B90,0,520,101,80,"ESC",@LOAD;MENU.SKIN@
    /, Y, BACK SLIDER FILE PATH
    Y01,"SLIDER_BATTERY\SLIDER_*.GIF"
    Y02,"VSLIDERWOOFER\SLIDER_*.GIF"
    /, S, X, Y, W, H, FORECOLOR R;RGB, G, B, BACKCOLOR R;RGB, G, B, SELECTED COLOR R;RGB, G, B, SELECT COLOR R;RGB, G, B, TRS, FONT SIZE;FONT, FONT NAME
    S01,678,39,102,20,62,103,70,20,V,01," ",015,"GPSSIGNAL","GPS SIGNAL"
    S02,506,244,269,22,121,203,411,27,H,02,"VSLIDERWOO FER\POINTER.GIF",15,"$SPEEDZONEMONITOR$",
    /, I, X, Y, W, H, CODE;INDICATORCODES
    I01,698,521,107,80,"MASTERMUTE"
    I,668,6,21,21,"RM_1STAR"
    I,692,6,21,21,"RM_2STAR"
    I,716,6,21,21,"RM_3STAR"
    I,740,6,21,21,"RM_4STAR"
    I,764,6,21,21,"RM_5STAR"
    I,70,7,52,25,"SHUFFLE"
    I,13,7,50,25,"REPEAT"
    I16,320,4,32,31,"HEADING"
    I,124,7,54,25,"ONLINE"
    END
    This is my screen file .
  4. #14
    Aug 2006
    Sun Diego
    I noticed a space in the button command in your skin file:
    can you confirm that there is no space?
  5. #15
    May 2008
    Bordeaux, France
    Hey Sal R,
    I confirm you that I have no space before TESTSWITCHON .
    Is ok ?
