Configure your Radio to use D-Link, then Select the option to use the Line-In Plugin -- be sure to download/install the line in plugin. Then select the AUX line to be muted/unmuted when turning off/on the radio..
If your audio card already plays the audio from AUX in by unmuting the line, then all you'd need is to select D-Link and select the audio line to mute/unmute in RRConfig.
LinkBack URL
About LinkBacks
