Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 74
Thread: coverjuke 1.51 embeding?
  1. #11
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    yeh, I think I might send send Leb a message, maybe it can be fixed in the next update.
  2. #12
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    scroll bar is there , try it standalone not in rr , and you see the scroll bar it gets cut off when embedding.
  3. #13
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    Quote Originally Posted by brandensin View Post
    sure... first, window name is "freeglut", not coverjuke... That's all u need to change. it should work... and if you want, u can get rid of clip area now ... just add application area instead...
    Code:
    "loadCOVERJUKE","LOAD;coverjukevideo.skin;!freeglut;$RRPATH$plugins\Coverjuke\coverjuke.exe;!freeglut"
    Just for heads up, there's no space on ("!freeglu t") I was having probelm reaizing until I changed it. the winsppy helped sort out the confusion. Thanks though much help. The 1.52V embeds perfectly.
    Did it.. Done it... now I got to keep the neighbors kids away!!
  4. #14
    Aug 2008
    Code:
    LOAD;coverjukevideo.skin;!freeglut;C:\Progam Files\RideRunner\Plugins\Coverjuke\coverjuke.exe;!freeglut
    no commands in EXbl.ini or rr.ini
  5. #15
    Sep 2008
    Baton Rouge
    Quote Originally Posted by jessekilner View Post
    It doesn't embed "perfectly" but it's close. See my post above about the black bar at the top of the page, which cuts off the scroll bar. Anyway, this is due to how the application is written when it wants to go into fullscreen. Basically the Windows Title Bar sits over the Application, and when in full screen, it is just removed. I have been messing with skinbedder lately, and have gotten the black bar cropped out, but still no scroll bar. I may look into the ini's of coverjuke to see if I can reposition it somewhere. Also, in the config screen where you can choose what to send to an external audio player, it is backwards. "List of File" sends the folder path, and "Folder" sends a list of all the songs in the Folder, List of file works best for sending directly to Winamp.
  6. #16
    Aug 2008
    Im not sure I follow you on the send file thing. can you post with highlight, I think i had a issue along these lines as i get the winamp to play the file in RR but it only sends the first 8 tracks on any album... strange..
  7. #17
    Sep 2008
    Baton Rouge
    This Parameter should be set to "List of File" for Winamp. This actually sends the folder to Winamp. If you choose the "Folder" option, it sends a string list of all the songs in the folder. So it's backwards. Set it to "List of Folder" and see if that will load the whole the album. If you use it inside of RR, then you will have to send the command, "RELOADLIST" to update RR's playlist and all the labels and stuff in RR, even the Album art.
    I'm working on updating the old AutoIT script that was in the old thread to make it work with this new version. If you want, I can send it to you when I finish. This will allow it to send commands to RR to load pop-up window of the songs like on the ipod and stuff.
    If I wasn't clear on somethin, just let me know.
  8. #18
    Aug 2008
    i must have something missing, My config is blank shows nothing. I figured this was still in developement. I have downloaded this 3-5 times with same effect. am I suppose to reg some .bat files? i was doing all my settings in the .ini file
  9. #19
    Aug 2008
    I'd appreciate that. Thank you
  10. #20
    Sep 2008
    Baton Rouge
    There is a bug with the Config on XP. Right click the shortcut and go to properties and change the compatibility to open in Windows 2000 mode, this should allow it to show correctly.
  1. Coverjuke, (openGL)
    By EL CAMINO in forum RR Plugins
    Last Post: 10-29-2011, 03:17 PM
  2. Embeding AutoEnginuity
    By dnr250 in forum Road Runner
    Last Post: 11-24-2008, 03:04 AM
  3. I need a little help with embeding in CF 1.4
    By wodie in forum Centrafuse
    Last Post: 08-02-2005, 09:31 AM
  4. embeding in frodo
    By djmickyg in forum FreeDrive
    Last Post: 06-18-2005, 05:22 AM
  5. Embeding CoPilot Live?
    By aoLhaTer in forum GPS
    Last Post: 06-09-2005, 03:45 AM
