Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 74
Thread: coverjuke 1.51 embeding?
  1. #41
    Nov 2008
    Note: Skinbedder does not support "Program Files", which is why the PROGRA~1 is listed
    see the SKINbedder section in the forums for help if with this if your coverjuke.exe is
    not located in "Program Files"
  2. #42
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Yeh, I had to read through the Skinbedder forums to figure that out as well.
    Im not saying you cant have Coverjuke in program files somewhere, I'm saying you cant put "Program Files" in the file path. You have to put PROGRA~1 to access program files in skinbedder.
    Ex:
    C:\Program Files\Coverjuke\coverjuke.exe
    C:\PROGRA~1\Coverjuke\coverjuke.exe
    These are equivalent
  3. #43
    Nov 2008
    ok it works!!!
    but i use the Teknik2 skine how do i set the left & right button?
    CJ_PREVALBUM","ACTIVATE;CoverJuke||WAIT;0.1||SENDKEY;{LEFT}||SETTOPMOST;RR;TRUE"
    "CJ_NEXTALBUM","ACTIVATE;CoverJuke||WAIT;0.1||SENDKEY;{RIGHT}||SETTOPMOST;RR;TRUE
    these commands don't work for me
    also i want the V button will do the sams thing as i as iclick on the album (open the coverjuke_playlist.skin)
    thanks!!!
  4. #44
    Sep 2008
    Baton Rouge
    Ok, here is the deal,
    SkinBedder is intercepting the keystrokes and not passing them to Coverjuke. There was some discussion on this in the skinbedder forum, but there is a solution using an AutoIT script, so I will look into that. Hopefully someone with a little better AutoIT knowledge will see this and can punch it out real quick, because I'm going to have to read a bit.
  5. #45
    Nov 2008
    thanks man!
  6. #46
    Sep 2008
    Baton Rouge
    Quote Originally Posted by dotcom1 View Post
    thanks man!
    Nvm Dotcom, I fixed it and will update all attachments and README to support sending any commands to Coverjuke. I'll post the part of the README on here as well.
  7. #47
    Sep 2008
    Baton Rouge
    CJSend
    I have attached a .zip of the CJSend.exe that can be used to send keys to coverjuke.
    I also updated the previous attachment with these instructions and the CJSend.exe
    Attachment 54004
    Instructions:
    Add CJSend.exe to your coverjuke directory and make buttons on you skin with the following button codes.
    Code:
    SENDING KEYS TO COVERJUKE
    1. To send a key to coverjuke simply make a button in your skin that executes the key stroke you want to send according
    to the following list:
    Note: The following list is based on your coverjuke directory being located in C:\Program Files\Coverjuke.  If it
    in a different location you will have to update the button code with the correct directory.
    DESC.			Button Code
    Next Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{RIGHT}"
    Prev. Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{LEFT}"
    Select Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{ENTER}"
    Skip to Letter		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{"letter"}"  -- Insert any letter (could even be set to a variable in RR, for quick searching)
    1st Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{HOME}"
    last Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{END}"
    Randon Album		"RUN;C:\Program Files\Coverjuke\CJSend.exe|{SPACE}"
    Jump Right 10 albums	"RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGDN}"
    Jump Left 10 albums	"RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGUP}"
    Close CoverJuke                 "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ESC}"  *New
    Here is a picture of a new skin I made that utilizes the new Sendkey ability.
    Attachment 54007
  8. #48
    Nov 2008
    you'r the best man!!!!
  9. #49
    Sep 2008
    Baton Rouge
    Thanks,
    If anyone has problems or questions, just ask away and I will do my best to give an answer
  10. #50
    Sep 2008
    Baton Rouge
    I've got something working thats going to require a whole new thread!
    See if you can spot whats new?
    xbox
    Attachment 54018
    And Coverflow
    Attachment 54019
    I'll post up with more details after my tests (actual tests).
    (Hint: No more Skinbedder)
  1. Coverjuke, (openGL)
    By EL CAMINO in forum RR Plugins
    Last Post: 10-29-2011, 03:17 PM
  2. Embeding AutoEnginuity
    By dnr250 in forum Road Runner
    Last Post: 11-24-2008, 03:04 AM
  3. I need a little help with embeding in CF 1.4
    By wodie in forum Centrafuse
    Last Post: 08-02-2005, 09:31 AM
  4. embeding in frodo
    By djmickyg in forum FreeDrive
    Last Post: 06-18-2005, 05:22 AM
  5. Embeding CoPilot Live?
    By aoLhaTer in forum GPS
    Last Post: 06-09-2005, 03:45 AM
