I have attached a .zip of the CJSend.exe that can be used to send keys to
coverjuke.
I also updated the previous attachment with these instructions and the CJSend.exe
Attachment 54004
Instructions:
Add CJSend.exe to your coverjuke directory and make buttons on you skin with the following button codes.
Code:
SENDING KEYS TO COVERJUKE
1. To send a key to coverjuke simply make a button in your skin that executes the key stroke you want to send according
to the following list:
Note: The following list is based on your coverjuke directory being located in C:\Program Files\Coverjuke. If it
in a different location you will have to update the button code with the correct directory.
DESC. Button Code
Next Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{RIGHT}"
Prev. Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{LEFT}"
Select Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ENTER}"
Skip to Letter "RUN;C:\Program Files\Coverjuke\CJSend.exe|{"letter"}" -- Insert any letter (could even be set to a variable in RR, for quick searching)
1st Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{HOME}"
last Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{END}"
Randon Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{SPACE}"
Jump Right 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGDN}"
Jump Left 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGUP}"
Close CoverJuke "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ESC}" *New
Here is a picture of a new skin I made that utilizes the new Sendkey ability.
Attachment 54007
