Page 1 of 8 12345678 LastLast
Results 1 to 10 of 74
Thread: coverjuke 1.51 embeding?
    Nov 2008
    in the old v' was a file "load_cj.exe" that caused him to embed in RR skin Teknik2 but now he does't
    my question how i can embed and resize this v in RR skin?
    "CJ_LOAD","LOAD;coverjuke.skin;CoverJuke;$skinpath$coverjuke\coverjuke.exe;coverjuke
    this command don't work for me
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    CJ now embeds without external scripts , a new update for this is being worked on , there are loads of changes that make it more carpc friendly so what the coverjuke thread in plugins section for updates when ready
    ENJOY
    Dec 2007
    sweet.. didn't know that until just now... i just tried it and yes sir it did embed correctly... Thanks
    Nov 2008
    Quote Originally Posted by brandensin View Post
    please tell me what v' you use?
    and how you embed it in RR?
    Dec 2007
    sure... first, window name is "freeglut", not coverjuke... That's all u need to change. it should work... and if you want, u can get rid of clip area now ... just add application area instead...
    Code:
    "loadCOVERJUKE","LOAD;coverjukevideo.skin;!freeglut;$RRPATH$plugins\Coverjuke\coverjuke.exe;!freeglut"
    Nov 2008
    Code:
    thanks man!!!
    but it not resizeing properly
    coverjuke.ini
    width = 780
    height = 414
    and the "SENDKEY" command not working
    CJ_PREVALBUM","ACTIVATE;coverjuke||WAIT;0.1||SENDKEY;{LEFT}||SETTOPMOST;RR;TRUE"
    does't make any difference do you have any idea?
    Dec 2007
    man.. i don't know what you are doing with all that send key stuff... when embedding, width and height in coverjuke.ini are meanless.. Doesn't matter what you put in there... it will resize according to the application area you defined in a skin.. If you are using el camino's plugin, you have better luck posting there for your solution....
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Brandensin,
    When embedding using the same command as you, I get what looks like the title bar (in black) at the top of the application area. This causes the scroll bar of the application not to show. Are you having this issue as well?
    In picture, application area is defined below the top bar to the top of the button menu.
    Dec 2007
    yes, i got that black area as well.. but i see everything... what scroll bar are you talking about? The one on the bottom you use to flip the album? you have to set the flag in config file to unhide it..
    Dec 2007
    shoot... just confirmed, you are right.. i don't see the bar either... well.. no biggie... i don't use it anyway.... but it is weird..
  1. Coverjuke, (openGL)
    By EL CAMINO in forum RR Plugins
    Last Post: 10-29-2011, 03:17 PM
  2. Embeding AutoEnginuity
    By dnr250 in forum Road Runner
    Last Post: 11-24-2008, 03:04 AM
  3. I need a little help with embeding in CF 1.4
    By wodie in forum Centrafuse
    Last Post: 08-02-2005, 09:31 AM
  4. embeding in frodo
    By djmickyg in forum FreeDrive
    Last Post: 06-18-2005, 05:22 AM
  5. Embeding CoPilot Live?
    By aoLhaTer in forum GPS
    Last Post: 06-09-2005, 03:45 AM
