Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 64
Thread: Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you)
  1. #31
    MySQL Error
    Oct 2004
    chuck ,
    if u dont want a plugin to load on some skins and load on others
    i wouldnt call that a global plugin!!!
    a good global plugin is say
    MJS UAS
    or
    SKINTOOL
    here is what the output of debug.txt looks like now
    here is a snip of plugins loading
    Code:
    1/8/2009 4:09:16 PM: Plugin Manager: loading Global Plugins...
    1/8/2009 4:09:16 PM: Plugin Manager: RRMJSUAS(.NET) plugin found.
    1/8/2009 4:09:16 PM: Plugin Manager: MovieTimes plugin found.
    1/8/2009 4:09:16 PM: Plugin Manager: RRExtended plugin found.
    1/8/2009 4:09:16 PM: Plugin Manager: SkinTool plugin found.
    1/8/2009 4:09:16 PM: Plugin Manager: Plugin loaded (Global): RRMJSUAS
    1/8/2009 4:09:16 PM: Plugin Manager: Plugin loaded (Global): MovieTimes
    1/8/2009 4:09:16 PM: Plugin Manager: Plugin loaded (Global): RRExtended
    1/8/2009 4:09:16 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    1/8/2009 4:09:16 PM: Plugin Manager: loading Global Plugins Completed.
    1/8/2009 4:09:16 PM: Plugin Manager: loading SkinDir Plugins...
    1/8/2009 4:09:16 PM: Plugin Manager: Warning loading MovieTimes (Attempt load more then once, most likely duped in globals and/or in skin).
    1/8/2009 4:09:16 PM: Plugin Manager: loading SkinDir Plugins Completed.
    1/8/2009 4:09:17 PM: Plugin Manager: Warning loading MOVIETIMES (Attempt load more then once, most likely duped in globals and/or in skin).
    1/8/2009 4:09:17 PM: Plugin Manager: Error loading (menu.skin): RRGas (ActiveX component can't create object)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #32
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I still think there should be an option to turn it off in the Skin.ini file so the skinners can have time to catch-up with it.
    AUTOLOADPLUGINS=True/False
    2001 S10 ZR2
    Chucks Skin - to old
  3. #33
    Aug 2004
    Germany
    Another suggestion:
    At the moment you can just specify a list of screens to be preloaded when RoadRunner starts. It'd be nice if screens would also be preloaded when switching skins. Of course this should happen in the background. Or if that's not possible: preload screens of day AND night skin at RoadRunner startup (with a command like PRELOADNIGHT=1)
    I'm asking because I preload screens of my day skin for faster access. But when I switch to the night skin the screen changes are slower because the screens of the night skin are just loaded at first access. It's not much, but still somewhat annoying. That's why I stopped using two skins.
  4. #34
    MySQL Error
    Oct 2004
    chuck, the autoplugsisnt really needed
    but i started working on some real management of plugins
    prob not complete for JAN release
    but i would like you to work with me...
    if you're interested PM me
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #35
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Yes I am interested in working with you on this – don’t know how I could help but I can test and make suggestions.
    I guess I started this because I just can not run all the plugins at the same time in my truck because it takes too much power. So I made a simple menu to turn them on and off as need and a way to know if the plugin was on or off when I started them.
    “RRUPD8”,”BYIND;RRUPD8;PLUGINMENU<<NEWRRUPD8”
    “NEWRRUPD8”,” RRUPD8”
    So if a plugin was not on -or in the Plugins.txt file- the plugin menu will pop-up to let you know.
    With the new way my $hit will not work no more unless you do not put the plugins in the "SKINPATH/Plugins/" or "Road Runner/Plugins/" witch is no big deal but if I wanted to release my new skin then everyone who uses it would have trouble.
    And I am sure other skins are in the same boat with the Plugins.txt file method so thats why I suggested AUTOLOADPLUGINS=True/False in the Skin.ini file.
    2001 S10 ZR2
  6. #36
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Chuck View Post
    he's well on his way to replacing all that super RR coding u've done with a simple and clean interface.. all built in Mitch is the man!
    Live mp3Car Facebook Chat
  7. #37
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Seeing as you are using that as an example, I take it the indicator works
  8. #38
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by Enforcer View Post
    Yes
    the red ones have indicator
    2001 S10 ZR2
  9. #39
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well the next updates for RRGas, RRStopwatch, RRPetrol, RRGrid will all have the indicator, if they don't already.
    Assuming an update is needed.
  10. #40
    Raw Wave
    Jun 2002
    Virginia
    The fact that you can't spell elves, kind of justifies my question.
    And the fact that you use "your" for "you're" further justifies the question.
