Page 1 of 7 1234567 LastLast
Results 1 to 10 of 64
Thread: Jan 2009 *NEW RoadRunner updates* (coming soon to a pc near you)
    MySQL Error
    Oct 2004
    IT is coming
    the elves where hard at work....
    got a bunch of new skin commands
    a complete new plugin loader
    here is the newest history as of now:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    01/05/08
    ! Plugin processing additions
    Plugins are now loaded via 3 methods, in this order: GLOBAL, SKINDIR, "menu.skin"
    [All plugins must meet the required class (.RRExtension) and be registered as com]
    -GLOBAL: the "Road Runner/Plugins/" directory is searched for .dlls that qualify (recusively)
    when found, they are tested for requirements and loaded. This type of plug in
    is ONLY loaded ONCE, and never unloaded (except shutdown). Some good examples would be
    "Skintool", "RRExtended", and "MJSGUAS"
    -SKINDIR: the "SKINPATH/Plugins/" ("SKINPATH" is the current skin directory)
    is loaded and unloaded as required by skinchange.
    - "menu.skin": same as before, loaded based on skin code "X,pluginname"
    to simply have a skin use a plugin, install it in the skinpath, example "movietimes"
    "C:\Program Files\Road Runner\Skins\Carwings_Dynamic\Plugins\MovieTimes"
    no more need to edit menu.skin or some skins use "plugins.txt"
    12/15/08
    + "ONSCREENCHANGE" Event called when screen is changed
    + "ONCOMMANDINVALID" Event Called when no matching cmd
    12/14/08
    * "RELOADSCREEN" improved, now "RELOADSCREEN;TRUE" will preserve list positions, and custom lists (CL)
    * "RELOADSKIN" improved, now if followed by a "load;skin_name.skin" then menu.skin will not display (blink)
    12/10/08
    * Improvements to "ACTIVESOURCEID" (now will be a bit more accurate with 5 (Audio))
    + Added "PLAYSOUND" skin command - "PLAYSOUND;wavefile.wav"
    * SiriusComm - improvements for new design of SC-C1 interface, also on radios that are NEW and unactivated (free preview channels)
    + "CLOSEWINAMPONEXIT=TRUE/FALSE" - RR.ini setting, its default is true, but if you want to keep it running, when you exit from rr, set to false
    + Added "mediaInfo.dll" to installer
    12/08/08
    + "SETSKIN" skin command, "SETSKIN;skinpath", will set new skinpath, and perform a "RELOADSKIN"
    + "SETVOL;MASTER;xx" special param added, will set master volume control level 0 - 100, ex. "SETVOL;MASTER;50"
    + Weather graphics .png files are now accepted, falls back to .gif files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Wow, just read the entire changelog, looks like you have added some features that are well thought out and have been needed in RR for awhile! The plugin handling sounds so much simpler now. Thanks again for the hard work and dedication to the RR project Mitch!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Is there prevention against the same plugin being loaded from two or more different locations.
    ie if it has already been loaded from the plugins folder, is it prevented from being loaded via the menu.skin and the skins/plugin folder?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Did you just seriously ask that???? Your joking right?
    Us..elevs weren't born yesteday...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    For him,you need to put it in writing. NOTEPAD!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The fact that you can't spell elves, kind of justifies my question.
    Constant Bitrate Jfive96's Avatar
    Sep 2005
    Grand Prairie,Texas
    - -This is great news.- -
    - -Take a good look at yourself while at the computer, if your in a t-shirt and talking sh@t on the internet. Chances are you fall in the "Internet Tough Guy" catagory.- -
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Very very good
    Will the "ONCOMMANDINVALID" set a lable with that invalid command in it so you can have a menu pop-up with that lable?
    Code:
    You could do stuff like
    "ONCOMMANDINVALID","SETVARBYCODE;DATE;DATE||SETVARBYCODE;TIME;TIME||SETVARBYCODE;RRSCREEN;RRSCREEN||SETVARBYCODE;INVALIDCOMMAND;INVALIDCOMMAND||ADDTOFILE;$SKINPATH$INVALIDCOMMAND.txt;= $DATE$ $TIME$ $RRSCREEN$ $INVALIDCOMMAND$ ||PLAYSOUND;$SKINPATH$Beep.wav"
    Also would be nice to have a indicator for plugins that are running.
    BYIND;PLUGIN;Movie;=NO<<=YES"
    2001 S10 ZR2
    Chucks Skin - to old
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That's really the responsibility of the plugin creator to do that...I have adapted that new std on my released plugins execpt RRMedia which will be done the its next update..
    Ya you can do that with the invalid cmd, as its just a custom event that is fired..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Jfive96 View Post
    Connections Etc.
    *J.Crawford*
    Tires, Rims, Auto Parts & Service and EVERYTHING in between!!!
    Call : 214-552-6651 or email connectionsetc@gmail.com for all orders and any additional information.
    OT...Free Advertising?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
