Results 1 to 10 of 11
Thread: Chucks simple plugin settings menu
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just a simple menu that turns on and off adds, deletes and rearranges plugins all in RR code and no need to have another plugin to adjust plugins.
    Uses the Plugins.txt method but it does not read it just makes a new one each time.
    Click to turn on and off.
    Hold to add or delete.
    Code:
    PLUGIN_MENU.Skin
    RoadRunner Skin
    Chucks Skin "Charles J Richards Jr"
    /,Menu.jpg size 650x400
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,133,338,80,40,150,150,150,24,"Arial:B","=Exit","CENTER"
    L,326,338,278,40,150,150,150,24,"Arial:B","=Save and Reload","CENTER"
    L,23,21,605,30,150,150,150,18,"Arial:B","=Plugins Setting List","CENTER"
    L,23,58,605,20,70,70,70,12,"Arial:B","=Hold To Add or Change Plugin","CENTER"
    L,25,80,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET01;=$PLUG01$","LEFT"
    L,25,130,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET02;=$PLUG02$","LEFT"
    L,25,180,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET03;=$PLUG03$","LEFT"
    L,25,230,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET04;=$PLUG04$","LEFT"
    L,25,280,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET05;=$PLUG05$","LEFT"
    L,229,80,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET06;=$PLUG06$","LEFT"
    L,229,130,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET07;=$PLUG07$","LEFT"
    L,229,180,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET08;=$PLUG08$","LEFT"
    L,229,230,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET09;=$PLUG09$","LEFT"
    L,229,280,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET10;=$PLUG10$","LEFT"
    L,436,80,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET11;=$PLUG11$","LEFT"
    L,436,130,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET12;=$PLUG12$","LEFT"
    L,436,180,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET13;=$PLUG13$","LEFT"
    L,436,230,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET14;=$PLUG14$","LEFT"
    L,436,280,191,30,150,150,150,16,"Arial:B","BYVAR;PLUGINSET15;=$PLUG15$","LEFT"
    L,25,80,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG01$","LEFT"
    L,25,130,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG02$","LEFT"
    L,25,180,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG03$","LEFT"
    L,25,230,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG04$","LEFT"
    L,25,280,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG05$","LEFT"
    L,229,80,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG06$","LEFT"
    L,229,130,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG07$","LEFT"
    L,229,180,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG08$","LEFT"
    L,229,230,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG09$","LEFT"
    L,229,280,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG10$","LEFT"
    L,436,80,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG11$","LEFT"
    L,436,130,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG12$","LEFT"
    L,436,180,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG13$","LEFT"
    L,436,230,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG14$","LEFT"
    L,436,280,191,30,70,70,70,16,"Arial:B","BYVAR;RUN;=$PLUG15$","LEFT"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,321,340,285,36,"PLUNGINSAVERELOAD",""
    B,20,73,199,44,"BYVAR;PLUGINSET01;SETVAR;PLUGINSET01;1<<SETVAR;PLUGINSET01;0",@ESC||OSKTOCMD;PLUG01;OPENPLUGINMENU||OSKTEXT;$PLUG01$@
    B,20,123,199,44,"BYVAR;PLUGINSET02;SETVAR;PLUGINSET02;1<<SETVAR;PLUGINSET02;0",@ESC||OSKTOCMD;PLUG02;OPENPLUGINMENU||OSKTEXT;$PLUG02$@
    B,20,172,199,44,"BYVAR;PLUGINSET03;SETVAR;PLUGINSET03;1<<SETVAR;PLUGINSET03;0",@ESC||OSKTOCMD;PLUG03;OPENPLUGINMENU||OSKTEXT;$PLUG03$@
    B,20,222,199,44,"BYVAR;PLUGINSET04;SETVAR;PLUGINSET04;1<<SETVAR;PLUGINSET04;0",@ESC||OSKTOCMD;PLUG04;OPENPLUGINMENU||OSKTEXT;$PLUG04$@
    B,20,272,199,44,"BYVAR;PLUGINSET05;SETVAR;PLUGINSET05;1<<SETVAR;PLUGINSET05;0",@ESC||OSKTOCMD;PLUG05;OPENPLUGINMENU||OSKTEXT;$PLUG05$@
    B,224,74,199,44,"BYVAR;PLUGINSET06;SETVAR;PLUGINSET06;1<<SETVAR;PLUGINSET06;0",@ESC||OSKTOCMD;PLUG06;OPENPLUGINMENU||OSKTEXT;$PLUG06$@
    B,224,123,199,44,"BYVAR;PLUGINSET07;SETVAR;PLUGINSET07;1<<SETVAR;PLUGINSET07;0",@ESC||OSKTOCMD;PLUG07;OPENPLUGINMENU||OSKTEXT;$PLUG071$@
    B,224,173,199,44,"BYVAR;PLUGINSET08;SETVAR;PLUGINSET08;1<<SETVAR;PLUGINSET08;0",@ESC||OSKTOCMD;PLUG08;OPENPLUGINMENU||OSKTEXT;$PLUG08$@
    B,224,223,199,44,"BYVAR;PLUGINSET09;SETVAR;PLUGINSET09;1<<SETVAR;PLUGINSET09;0",@ESC||OSKTOCMD;PLUG09;OPENPLUGINMENU||OSKTEXT;$PLUG09$@
    B,224,273,199,44,"BYVAR;PLUGINSET10;SETVAR;PLUGINSET10;1<<SETVAR;PLUGINSET10;0",@ESC||OSKTOCMD;PLUG10;OPENPLUGINMENU||OSKTEXT;$PLUG10$@
    B,429,74,199,44,"BYVAR;PLUGINSET11;SETVAR;PLUGINSET11;1<<SETVAR;PLUGINSET11;0",@ESC||OSKTOCMD;PLUG11;OPENPLUGINMENU||OSKTEXT;$PLUG11$@
    B,429,123,199,44,"BYVAR;PLUGINSET12;SETVAR;PLUGINSET12;1<<SETVAR;PLUGINSET12;0",@ESC||OSKTOCMD;PLUG12;OPENPLUGINMENU||OSKTEXT;$PLUG12$@
    B,429,173,199,44,"BYVAR;PLUGINSET13;SETVAR;PLUGINSET13;1<<SETVAR;PLUGINSET13;0",@ESC||OSKTOCMD;PLUG13;OPENPLUGINMENU||OSKTEXT;$PLUG13$@
    B,429,224,199,44,"BYVAR;PLUGINSET14;SETVAR;PLUGINSET14;1<<SETVAR;PLUGINSET14;0",@ESC||OSKTOCMD;PLUG14;OPENPLUGINMENU||OSKTEXT;$PLUG14$@
    B,429,274,199,44,"BYVAR;PLUGINSET15;SETVAR;PLUGINSET15;1<<SETVAR;PLUGINSET15;0",@ESC||OSKTOCMD;PLUG15;OPENPLUGINMENU||OSKTEXT;$PLUG15$@
    B,99,340,148,36,"EXIT",""
    END
    /,ExecTBL.ini - File
    /,1C---------------------Chucks Plugin Sittings--------------------------------------------------------------------------------------------------------------------
    "PLUGINLIST","MENU;PLUGIN_MENU.Skin||LOADPLUGINLIST"
    "OPENPLUGINMENU","MENU;PLUGIN_MENU.Skin"
    "PLUNGINSAVERELOAD","SETPLUGINLIST||MAKEPLUNGINLIST||SAVETOSKIN;PLUGINSLIST;$PLUGINSLIST$||RELOADSKIN||OPENPLUGINMENU"
    "MAKEPLUNGINLIST","WRITETOFILE;$SKINPATH$Plugins.txt;||BYVAR;PLUGINSET01;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG01$||BYVAR;PLUGINSET02;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG02$||BYVAR;PLUGINSET03;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG03$||BYVAR;PLUGINSET04;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG04$||BYVAR;PLUGINSET05;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG05$||BYVAR;PLUGINSET06;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG06$||BYVAR;PLUGINSET07;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG07$||BYVAR;PLUGINSET08;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG08$||BYVAR;PLUGINSET09;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG09$||BYVAR;PLUGINSET10;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG10$||BYVAR;PLUGINSET11;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG11$||BYVAR;PLUGINSET12;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG12$||BYVAR;PLUGINSET13;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG13$||BYVAR;PLUGINSET14;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG14$||BYVAR;PLUGINSET15;ADDTOFILE;$SKINPATH$Plugins.txt;=X $PLUG15$"
    "LOADPLUGINLIST","SETVARFROM;PLUGINSLIST;<<PLUGINSET01<<PLUG01<<PLUGINSET02<<PLUG02<<PLUGINSET03<<PLUG03<<PLUGINSET04<<PLUG04<<PLUGINSET05<<PLUG05<<PLUGINSET06<<PLUG06<<PLUGINSET07<<PLUG07<<PLUGINSET08<<PLUG08<<PLUGINSET09<<PLUG09<<PLUGINSET10<<PLUG10<<PLUGINSET11<<PLUG11<<PLUGINSET12<<PLUG12<<PLUGINSET13<<PLUG13<<PLUGINSET14<<PLUG14<<PLUGINSET15<<PLUG15<<"
    "SETPLUGINLIST","SETVAR;PLUGINSLIST;<<$PLUGINSET01$<<$PLUG01$<<$PLUGINSET02$<<$PLUG02$<<$PLUGINSET03$<<$PLUG03$<<$PLUGINSET04$<<$PLUG04$<<$PLUGINSET05$<<$PLUG05$<<$PLUGINSET06$<<$PLUG06$<<$PLUGINSET07$<<$PLUG07$<<$PLUGINSET08$<<$PLUG08$<<$PLUGINSET09$<<$PLUG09$<<$PLUGINSET10$<<$PLUG10$<<$PLUGINSET11$<<$PLUG11$<<$PLUGINSET12$<<$PLUG12$<<$PLUGINSET13$<<$PLUG13$<<$PLUGINSET14$<<$PLUG14$<<$PLUGINSET15$<<$PLUG15$<<"
    2001 S10 ZR2
    Chucks Skin - to old
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I didn't think that "simple" was in your matrix volulabary....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Well it "was" simple to use anyway
    2001 S10 ZR2
    Nov 2004
    St Louis
    Matrix, ...I was thinking more like M.C. Escher
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Chuck I hear you're releasing another skin soon.
    If you cant DODGE em, RAM em.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by Ramanator View Post
    Maybe if I can get everything working flawless without an installer –copy and paste to skin folder- and if I can distribute the plugins with it.
    The skin will have 50 built in commands and 100 user custom commands that all can be set to any of the 36 bottom button or used from the menu skin.
    RRmail and Movietimes that will read to you.
    Calculator with 5 memories.
    Auto player has auto streaming detect for internet radio.
    Lots of plugin skins and more user settings thru out.
    And lots and lots of other junk.
    I am not one for fancy looking skins just get to the point but if you want to make it fancy you only have to change 13 total simple *.jpg’s to completely change the look.
    But remember this skin is 1024x768 that can scaled down and it needs more cpu’s - 1.8ghz or higher by the time you have gps and all the other stuff on the pc running.
    2001 S10 ZR2
    Nov 2004
    St Louis
    Let the fun begin. Whenever you're ready to share I'd love to get a copy!
    Feb 2007
    Motor City
    Quote Originally Posted by Chuck View Post
    Maybe if I can get everything working flawless without an installer –copy and paste to skin folder- and if I can distribute the plugins with it...
    Your skin was the first one I used, worked well except when I tried to exit. It closed the bottom screen out but left the top and then it would freeze, never could get it to exit properly. The little ones got a kick out of the talking commands.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Plugins Manager
    Code:
    PLUGIN_MENU.Skin
    RoadRunner Skin
    END
    Hi Chuck,
    I love your skin and try to understand how it run .
    I tried the plugin manager and i have not the same screen than you .
    And is the good file format for Plugins.txt (after a Save and Reload)
    X TimeExecChuck
    X Milage
    X PLUG03
    X PLUG04
    X PLUG05
    X PLUG06
    X PLUG07
    X PLUG08
    X PLUG09
    X PLUG10
    X PLUG11
    X PLUG12
    X PLUG13
    X PLUG14
    Can you help me please ?
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    This is my old skin and it will not run right with the newest RR
    The plugin list will not work with the newest RR either you need the rr version just before the one released yesterday.
    I do have a menu that will work with newest RR and will post in a new thread
    2001 S10 ZR2
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. Cannot access settings menu
    By doublet in forum FrodoPlayer
    Last Post: 06-23-2007, 01:09 AM
  3. Replies: 5
    Last Post: 03-25-2004, 04:22 PM
  4. Enhancements to Winamp LCD Plugin
    By TiTi in forum Software & Software Development
    Last Post: 11-11-2002, 01:24 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
