Page 13 of 17 FirstFirst ... 34567891011121314151617 LastLast
Results 121 to 130 of 168
Thread: RR 01/2009 ... Plenty of news..
  1. #121
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it will always be "Road Runner" to me
    As I see it, we all here in the forums will always think of it as "Road Runner" -- it can stay as our community's "little secret"
    Ride Runner RR's Myspace
  2. #122
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    well thank god we can still call it RR.. we all mostly called it RR most of the times anyways
  3. #123
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    I'm a little late to this party. Have really been focused on other projects for the past few months. But anyway...
    Congratulations Guino! I hope you and RideRunner see all the success you deserve. Your software is definitely some of the best there is.
    Is it that it's fun? Or that it lets you forget yourself?
  4. #124
    Feb 2008
    All The Best
    All the best Guino I know your have a great product there. Thanks for everything you have done with Road Runner, I know its not the end, just mearly the begining.
    :cheers:
  5. #125
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    I copied files over to the roadrunner folder and replaced, upon closing "riderunner" I get a error roadrunner combatibility .exe, I completely removed roadrunner and riderunner then just installed the riderunner from the website and I still get the same combatibility error.. everything else works great. No problems it just does the error upon exiting. Anyone else have this problem?
    Did it.. Done it... now I got to keep the neighbors kids away!!
  6. #126
    MySQL Error
    Oct 2004
    Quote Originally Posted by jessekilner View Post
    define "installed"... did you use the INSTALLER?
    also could you screen capture the error
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #127
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by Enforcer View Post
    JUst downloading.
    And I thought my download procedure was convoluted.
    Well yours still sucks too.
    Will be interested to see where/how this goes for you guys.
    Tidder
    Try RevFE
  8. #128
    Jul 2006
    Brisbane, Australia
    I'm also a latecomer to the party too, and congratulations on the new venture Guino, my RR install is in an offroad vehicle and with a new Xenarc monitor dying in short order, I am interested to look at this new hardware when it is available. The bouncing in a Jeep testing made me sit up and look.
    I don't see that a helper application is required for backwards compatability as this should be built into RiR instead. I've done a bit of work with creating a window that masquerades as another application to embed a particularly cantankerous program into RR. Check out the OziExplorer GPS Embedded thread in my signature.
    RiR just needs to open a hidden window with the same name and class as RoR and ferry WM_COPYDATA messages to RiR. I know you guys use COM in VB now and I would have thought the same technique could also be used so the RoR object passes requests to RiR. Perhaps an RR.INI variable to disable backwards compatibility might be nice to cut down on the memory overhead where the hddden window was not required.
    I've got some C source I can share if you are interested, just let me know and I'll dig it up and add a few annotations.
    Anyway guys, my monitor has been repaired and is on its way back from Xenarc to Australia so this will certainly give me some new enthusiasm for RR when it turns up in a few days. Keep up the good work!
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  9. #129
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by rodweb View Post
    RideRunner already has a hidden "RoadRunner" window to forward mesages (when RoadRunner.exe isn't used), it also makes sure the RoadRunner COM objects still work. You don't exactly "NEED" RoadRunner.exe -- it's just that some SCRIPTS check for the PROCESS NAME (RoadRunner.exe) and this causes them to not work correctly. So the only solution is to create an actual process with that file name, which can be done by code, but it's just as simple to make a separate exe.
    There's hardly any overhead in the backwards compatibility (when not using RoadRunner.exe) -- the window is just a static reference/handle with a sub of 5 lines to forward messages to the "RideRunner" window, and the COM objects are just two registry entries (so it uses no memory whatsoever). If you don't use any fancy scripts that check for RoadRunner.exe you can simply delete/rename roadrunner.exe and you will save some memory used for that process, but if some of your script/skin components don't close or run correctly, they it's because they're checking for Roadrunner.exe process and not finding it -- hopefully once those scripts are updated, this roadrunner.exe won't be necessary at all.
  10. #130
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just installed the new RR in my truck and Sirius will not work now.
    Was listing to Sirius in RR shutdown RR installed new RR then restarted and no Sirius but xm and radio still works but no Sirius. So I started a real old RR and Sirius works. I believe it has to do with the new SiriusComm.dll because if I start last months RR it will not work ether now and if I unregister the popup comes up. Wished I backed up RR folder so I could see if the older last months SiriusComm.dll still would have worked.
    EDIT
    SiriusComm.dll ver. 2.7.0.2 date 7-11-2008 works with last RR but not new RR
    SiriusComm.dll ver. 2.8.0.1 date 1-14-2009 not working for me
    2001 S10 ZR2
    Chucks Skin - to old
  1. RR installation instructions for Newbies
    By guino in forum RR FAQ
    Last Post: 10-20-2008, 10:58 PM
  2. Resume command throws RR to 100% - All fixed
    By obrienj in forum RR Bug Tracker
    Last Post: 08-25-2008, 09:37 PM
  3. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  4. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  5. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
