Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 168
Thread: RR 01/2009 ... Plenty of news..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 01/2009 ... Plenty of news..
    UPDATE Jan 24th, 2009:
    I have improved the RoadRunner.exe compatibility process to work correctly with girder without requiring any changes to girder settings. If you use girder you can just drop it over the install folder and you should be ready to go.
    The alternative of search/replacing the girder GML file to change "RoadRunner" to "RideRunner" is still best.
    IF YOU DON'T USE GIRDER OR HAVE ALREADY CHANGED YOUR GIRDER SETTINGS THERE'S NO NEED TO UPDATE THE FILE.
    Hello Everyone,
    For this release of the software, I wanted to give you some inside news on Road Runner ...
    Since November 2007 (yes: 2007) I have transferred copyrights of the Road Runner software (my share of the code) to a company called NISU Automotive SL, based in Madrid, Spain.
    NISU Automotive is a company founded by me (Wagner), Antonio (an experienced CEO) and a capital investment called "Grupo 8", a private investment group that has invested money to make this new project a reality.
    Of course, the above implies in a few changes. Starting from the time you saw me a little "distant" from the forums while I was working on the code that now belongs to this new company -- a "Pro" version of the software meant to run on specific hardware they'll be manufacturing. I want to assure everyone that any code contributed to the free/open version of RR was either removed, re-coded or a permission was obtained from the author through this process.
    Now, Instead of what you may think, NISU is not a software company, but a hardware company. We have been working hard all this time to design our own carpc solution with plenty of functions, and developing the "Pro" version of the software that is meant to control the specific hardware we will be manufacturing (and will be INCLUDED with it -- NOT SOLD), so in the next months a new CarPC (infotainment system) will be on the market with everything included. We will also manufacture some devices that I think will be welcome by all of you -- generally, devices that are small, efficient and with good quality, to mention a few: a bluetooth hands free hardware solution for integrating your phone into your pc's, a power amplifier, an intelligent shut down controller, a radio device, and more.
    Now, one of big the changes is in the name of the software: In order to avoid conflicts with Warner Bros regarding the brand Road Runner, we have legally registered the name Ride Runner, which will be the new name for the project from now on.
    Regarding Ride Runner (yes, already using the new name) nothing will change for us, users of this forum. There will "always" be a free version of the software -- which will always include the contributions made by users along the years. So please, comments like "this is the beginning of the death of rr" or "companies always destroy good projects like rr" have no place in this company. I am part of NISU, and i think i have never defrauded anyone here, and I've been available to all of you , to make reality that you have a free and fully featured front end in your cars. NISU does not have the intention to change this, and I never intended for that to happen (or I would have started to "Sell" software by itself a long time ago). So the free version will remain free version as it is today, and I will be here with all of you to help, and support, and implement any ideas/solutions you may desire into the software.
    So, from this release forward the software will be available at NISU's website for download -- it is still under construction but we have placed the new software installer and update for download (for free) so that you have a reliable/fast location to download from. Since the site was organized under an online shopping page, you'll need to register ONCE (and for free) so you can download the software and/or updates. This also makes it possible for you to receive notifications when a new version of the software is available.
    This is where the software will be available from now on:
    www.nisuautomotive.com ("Download Software" link on the top-right of the page)
    You'll then go to the software->application section and add what you'd like to download into your cart and proceed to "checkout". If you'd like to be notified about updates to the software, simply check the option during the checkout process.
    Regarding the changes to this version:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = bug fix
    ^ = Note
    01/19/09
    + "RoadRunner.exe" compatibility exe, forwards messages to "RideRunner.exe"
    01/17/09
    + "ONSOURCECHANGE" event fires when source changes (xm,sr,audio,radio)
    	("ACTIVESOURCEID" var is checked to determine new source.)
    01/16/09
    + "PRELOADSCRNS" skin command, will re-preload screens from rr.ini setting
      (good for after reloading a skin to regain back screen loading times)
    01/15/09
    * XM & SR Artwork updated
    1/14/09
    * RoadRunner is now RideRunner (because of commerical name conflict)
    01/13/09
    ! Plugin Manager v1.0 *** See Plugin Manager.txt ***
    # Winamp "END OF PLAYLIST" resume bug
    # "ONSCREENCHANGE" Event fix
    01/12/09
    + Plugin API Methods, "Enabled(state), Properties(item)"
    + "BACKGROUND" will try to load background file, if not found, it will try to load it from the "backgroundspath".
      If still not found, it will try to use the "defaultbg" and finnaly if not found, RGB Black.
    01/10/09
    ! Plugin Manager v0.5 *** See Plugin Manager.txt ***
    # Resumemusic positional information stored in resume.ini
    # fadevolumein fixed if source changes while ramping
    01/08/09
    # Saftey check put on "picspath" .ini setting to make sure path is valid
    12/15/08
    + "ONSCREENCHANGE" Event called when screen is changed
    + "ONCOMMANDINVALID" Event Called when no matching cmd
    12/14/08
    * "RELOADSCREEN" improved, now "RELOADSCREEN;TRUE" will preserve list positions, and custom lists (CL)
    * "RELOADSKIN" improved, now if followed by a "load;skin_name.skin" then menu.skin will not display (blink)
    12/10/08
    * Improvements to "ACTIVESOURCEID" (now will be a bit more accurate with 5 (Audio))
    + Added "PLAYSOUND" skin command - "PLAYSOUND;wavefile.wav"
    * SiriusComm - improvements for new design of SC-C1 interface, also on radios that are NEW and unactivated (free preview channels)
    + "CLOSEWINAMPONEXIT=TRUE/FALSE" - RR.ini setting, its default is true, but if you want to keep it running, when you exit from rr, set to false
    + Added "mediaInfo.dll" to installer
    12/08/08
    + "SETSKIN" skin command, "SETSKIN;skinpath", will set new skinpath, and perform a "RELOADSKIN"
    + "SETVOL;MASTER;xx" special param added, will set master volume control level 0 - 100, ex. "SETVOL;MASTER;50"
    + Weather graphics .png files are now accepted, falls back to .gif files
    12/02/08
    + "SETGAMMA" skin command, "SETGAMMA;red;green;blue"
    + "LOADLIST" radio support
    + "RELOADSCREEN" skin command, used when changing skin file live, reloads current .skin file (screen)
    + MatrixPC improvements to directory playlist functions
    + Support to Phidgets inputs and outputs
    + added minimize when video is using builtin or MPC (when u minimize RR, video now does too)
    * some code clean up in "Video"
    * Changes in last source resuming
    Now we all know that there are many plugins/scripts out there that work with the filename "RoadRunner.exe" -- and in an effort to keep backwards compatibility we've made a RoadRunner.exe process which starts and ends with RideRunner.exe -- if you don't think you use anything that requires that process/name, then you can simply rename/delete roadrunner.exe and likely most things will still work as usual. As you may know, we have been through a name change in the past and it was not such a big issue, so with the amount of work we did in testing and ensuring backwards compatibility, we hope this also should be a smooth process.
    In regards to working on the source code, anyone wishing to do this may use one of the previously released sources to add/modify it as necessary then send me the changes so I can merge them into the software. Or you may want to write me directly to talk about it first (since most things these days can be accomplished with extension plugins).
    I'll be updating my personal website (guino.home.insightbb.com) and the mirror with information/links as well as the documentation on integration and so on.
    Thanks for your continuing support and understanding,
    Guino.
    Attached Files Attached Files
    Ride Runner RR's Myspace
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Here's to new beginnings . This may come off as a shallow question, but are there images available for the new name of the software? Sorta like the "road runner" image passed around with a custom font?
    EDIT
    forgive me for bein stupid.. but how the heck do you download anything. The only options i see in firefox are add to cart and review. if i add to cart and process the order nothing happens.
    Live mp3Car Facebook Chat
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Sonicxtacy02 View Post
    EDIT
    Here's the step-by-step to download, and the new logo.
    (Start from www.nisuautomotive.com )
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Dowloaded and installed, thx and I wish you success in all you do, you have, and continue to, give so much...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Congratulations Guino! I wish you the best with your endeavors! You have spent countless hours developing and tweaking the RR code for free, and deserve to have a commercial product that can hopefully put some money in your pocket.
    If the hardware matches up with the code, you will have the most powerful front end on the market hands down!
    My Fiero Build Thread
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    good for you guino
    2001 S10 ZR2
    Chucks Skin - to old
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Good luck
    I wish you good luck with RideRunner
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    <Puts a muddy footprint in the thread.>
    You could have at least wiped your feet!
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Good luck Guino with your new venture
    The road is long but we are getting there.
  1. RR installation instructions for Newbies
    By guino in forum RR FAQ
    Last Post: 10-20-2008, 10:58 PM
  2. Resume command throws RR to 100% - All fixed
    By obrienj in forum RR Bug Tracker
    Last Post: 08-25-2008, 09:37 PM
  3. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  4. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  5. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
