Results 11 to 20 of 22
Thread: WinTV Radio
  1. #11
    Aug 2008
    Quote Originally Posted by guino View Post
    What's the radioline= setting in rr.ini ? make sure it's zero (radioline=0), then run the wintv radio by itself first and make sure it works.. then it should work fine in RR.
    Radio works fine by itself , radioline set to zero.
    Luanched radio before starting riderunner doesn't affect anything , since the first launch is OK , then when you go back the app is closed and when you enter radio again it starts and then is muted.
  2. #12
    Jan 2009
    can you help me a bit please?
    i've bought a wintv radio i set it up a made all settings but it still not playing from RR
    my radio path is c:\program files\wintv\wintv7\radio
    is this all right?
    thx
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The WinTV support in RR is made to work with THIS APPLICATION:
    http://www.hauppauge.com/html/radio.htm
    Newer versions of the application should still work IF the new version still accepts the same functions (which is unlikely if the application looks any different).
    If your WinTV card works with the application above, then it should work with RR by selecting WinTV and setting the path in RRConfig to the application above.
    Ride Runner RR's Myspace
  4. #14
    Jan 2009
    You know, that's the app that works with my WinTV Card. But its in a subfolder of wintv.
    in Order to help you about my setup i am using RR with DFX4.0 Skin
    is there a problem using that?
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It should work, what RR version are you using ?
    In the latest RR versions you should have installed the WinTV Radio plugin, then selected WinTV in the Config, and set the path to the application.
    Can you set those in RR.INI:
    debugmode=true
    debugfresh=true
    radiodebug=true in RR.INI
    wintvpath=c:\program files\wintv\wintv7\radio\
    Then run RR, go into radio, exit RR and post a ZIP of your debug.txt file so we can see what's going on?
  6. #16
    Dec 2009
    Guys, a little off topic question, does this WinTV Radio software work with the current WinTV 850 HVR external usb receiver or does this require totally different hardware? I'm asking because on the Hauppauge website I don't see any WinTV Radio hardware being featured, so either its discontinued or its implicitly a part of the products they are featuring?
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by maceo4 View Post
    This was a Radio Application from the manufacturer to control ANALOG FM radio. I don't believe it will work with newer models with digital tv/radio. If the device in question has an ANALOG FM tuner, than I'd assume it won't hurt to try it (though it's doubtful it will work).
  8. #18
    Jan 2009
    this is my debug file....
    thx again...
    Attached Files Attached Files
  9. #19
    MySQL Error
    Oct 2004
    sikam32, not a single bit of radio debug is in your debug.txt
    so 1, you didnt enable radio debug, 2, you dont have a radio type set up in rr.ini
    check rr.ini
    radiodebug=true
    Radio=WinTV
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  10. #20
    Jan 2009
    thats interesting
    can you please give me all the right commands to add to rr.ini??????
    it might be solve all the problems...
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 04:34 AM
  2. WinTV button not available in RRconfig
    By dstephens80 in forum Road Runner
    Last Post: 04-29-2008, 10:17 PM
  3. Replies: 3
    Last Post: 04-20-2008, 01:43 AM
  4. MP3 Player to GM Factory Radio
    By thewams in forum Newbie
    Last Post: 04-01-2007, 03:46 PM
