Results 1 to 10 of 11
Thread: Is there a simple way to add programs to RR?
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I've been searching around and read nearly all of the FAQ's and have yet to find an easy way to add a program/menu to Roadrunner. What I am basically looking for is a way to simple link an .exe to the skin and just make a button for it. Everything I have found says things like "Insert <werg345we4> to (whatever).ini then reg this and that.
    Perhaps I'm using the wrong program, becuase I understand that it is open source and always an ongoing project which I appreciate, however I feel at the moment unless I have some sort of computer science degree that it is difficult to add anything to is. Could anyone guide me in the correct direction?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Okay...make a button for it.
    Edit the graphic file and use skin editor to put the following code in the corresponding skin file in the button area:
    B,x,y,w,h,"RUN;<insert path to .exe here>",""
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Nov 2007
    Long Island, NY
    with the instructions from that post, and even the one it links to at http://www.mp3car.com/vbulletin/rr-f...cation-rr.html I still don't think its very clear.
    In the first one, I got lost at nearly the first step where I was told to copy those files. But I am unaware of where to find them. I looked in my default skin directory. Also I couldn't find any code buttons to replace in my skin ini, and I use LSX void.
    Are thee any skins which come with traffic cams and gas prices pre-installed?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Assuming you used the installer:
    1-Download a skin that has the "Applications" screen, for instance Brush Metal V2 (http://files.joat.co.nz/roadrunner/) -- the default Carwings skin DOES NOT have an applications screen.
    2-Look at the main RR folder -- you'll see a "LAUNCH" folder, now inside it there's a folder for each application setup, open one of the example folders like CALC and see what's in there, CALC.JPG and CALC.INI -- this is the perfect example.
    3-Make a new folder (in the same place where the CALC folder is) named MYAPP, go into the MYAPP folder you made, create a new MYAPP.INI file (using any text editor), add two lines to it: PATH=C:\BLABLA\MYAPP.EXE and WindowSearchString=MYAPP (Title of the window to embed -- take the CALC.INI file AS AN EXAMPLE.
    When you go into the application screen inside RR it will show the MYAPP option and allow you to run it.
    For help with Window title, and other forms of embedding application (i.e. to other skins) I recommend you to read the FAQs (ALL of them -- but AT THE LEAST the ones about embedding applications).
    Ride Runner RR's Myspace
    Nov 2007
    Long Island, NY
    Guino you are the man Thanks for everything, I'll try it out when I get home.
    Nov 2007
    Long Island, NY
    Guino,
    Worked like a charm Now why couldn't it be that simple in the first place?
    I'll try embedding it a bit later. Thank you once again.
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by guino View Post
    There is no "Launch" folder in the elite lite skin....so how do I add apps to the applications menu?????????
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    MySQL Error
    Oct 2004
    you dont, till you create a launch skin, just look at the one in carwings, it demos, notepad and calculator
    or if it does have the skin, you can create the folder
    which should technicaly already be there, in rr data profile folder
    like on my machine: C:\Users\mitchjs\Documents\RideRunner\Launch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2009
    Philadelphia, PA
    I looked in my users folder...and the launch folder was there......yayyy! Why is it not in the program folder with the launch.skin? If not for this post i would never have found the launch folder....thanks again
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. Replies: 1
    Last Post: 03-15-2008, 12:26 PM
  3. how can i add a sound in RR intro...
    By brandensin in forum Road Runner
    Last Post: 03-12-2008, 10:36 PM
  4. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  5. Ideas for new (maybe) functions in RR
    By vinzer in forum Road Runner
    Last Post: 10-06-2006, 08:56 AM
