Results 1 to 10 of 15
Thread: What Button is active on-Skin-start in my Skin?
    Jun 2007
    Germany
    How can I set a button as the first button, that would display with the On/Down Image?
    Background:
    My Skin is only for the Space Navigator, and, when i start in a Skin/Menu with only Buttons, i must use, for example, the arrow-left-or-right-Buttons to display the highlighted Button.
    Can I define a button as first button, which is indicated correctly?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    The first button to highlight is the first button in your skin file. If you have 6 buttons from left to right and you want to start on the left, then the first button is the most left one, the second button is the one next to it.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Exactly.... for a detailed example:
    Code:
    B01,56,134,184,77,"SkinButton1"
    B02,56,218,184,79,"SkinButton2"
    B03,54,310,185,70,"SkinButton3"
    B04,55,401,185,63,"SkinButton4"
    The very first button that would be highlighted would be the "B01", as it is first in the list.
    This list is an example of a single column of 4 buttons.
    If you wanted 2 columns, and have the cursor to go from the top left, then to the top right, then to the lower left and lastly the lower right, you would put them in this order:
    Code:
    B02,56,218,184,79,"SkinButton3"
    B03,54,310,185,70,"SkinButton2"
    So the bottom line is, you just put them in the order, in the actual skin file in the order that you want them to be in.
    My Fiero Build Thread
    Jun 2007
    Germany
    I notice, my English am too bad
    I made a video clip, where to see the problem.
    I would see in my Skin, when i entered a other *.skin-file (a menu with only 4 Buttons and 4 Labels), where the highlighted Button is.
    In the Video Clip, i select a mp3 File, then it open a menu. On this menu is no Button highlight and i must first push the "arrow-left-or-right-Button", to highlight a Button in the Skin.
    I hope, you see, what I mean.
    My Desire is, i go in this Skin, and a Button is immediately highlighted.
    Sorry for my bad English, i´m from German
    Attached Files Attached Files
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    If you select an item in your listad click enter then you execute a command as in
    "Menu;Select.skin" or what ever command you use to bring up this small menu. If you want to highlight a button on that menu, (you said you have to first hit the right or left arror to highlight a button), add this command to the command you use to bring up this menu, like this
    "Menu;Select.skin||Sendkey;{Right}"
    Now, when your menu loads, it will click the right arrow button for you and highlighting the first button.
    Mit anderen worten, das kommando das Du benuetzt um das menu aufzurufen muss das
    kommando Senkey;{Right} oder {left} beinhalten, wie das kommando das Ich forher benuetzt habe. Nach dem "Menu;musst du natuerlich dein eigenen .skin namen benuetzen.
    Ich hoffe du verstehst mein deutsch
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    MGD Ich verstehe! Das var sehr Gut! Ich war in Deutschland fur fier Jahre in der amerikanish Army. Ich habe nicht gesprochen Deutch in funfzen Jahren! Das ist stark zu erinnern
    Translation:
    MGD I understood, that was very good! I was in Germany for four years in the Army. I havent spoken it in like 15 years though, so its hard to remember!
    Speaking is one thing, my spelling in German I am sure needs some serious work! hahah
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Ich bin in Muenchen geboren und 1985 nach America ausgewandert. Ich kann Dich sehr gut verstehen.
    Jun 2007
    Germany
    hahaha you so cool, Guys
    Thanks, now i understand in German and in English, what you mean. I have forgotten the Sendkey Function!
    Your German is good, but your English is better! English is no problem for me reads, but write...
    Thanks for your Help! It´s a good Comunity here.
    @MGD: Dann kann ich ja in Zukunft per PM in Deutsch fragen, hehehe
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Sí mi amigo. Este no es un problema para mí.
  1. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 12:46 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  3. Subaru Impreza WRX Skin
    By Pez Are Yummy in forum RR Skins
    Last Post: 10-31-2007, 10:03 PM
  4. Replies: 10
    Last Post: 10-17-2006, 02:14 PM
  5. video player + gps skin button
    By lez in forum RR Skins
    Last Post: 12-31-2005, 04:35 AM
