Hi,
I found nothing in the Forum and the Skin Commands.txt.
I would execute a Command (defined only in execxtbl.ini) by an Indicator State in all/pre-defined Screens.
How can I make that?
Live mp3Car Facebook Chat
Can I write simply "ByInd..........","Play.." with or without ,XXX.skin?
Functions, as soon as the indicator goes on?
I thought, this goes only with Buttons...
I thought, I must write "!IndicatorXX","Play...". And this has no Function.
Thank you, I will test it!
You need to use BYIND to do this.
"BYIND;YOUR INDICATOR;PLAY"
replace the YOUR INDICATOR with the name of the indicator you have and then place the command after that.
I test this at the moment- The line of the exectbl.ini:
"BYIND;online;PLAY"
And then in Network-attitudes from WinXP deactivate LAN Connection- Has no Function. Re-activate from LAN, and wait till the Indicator(I see the Picture-Indicator) was on, but also no Function.
You need to put this line "BYIND;online;PLAY"
in the skin where the indicator is located. For example, you have the ONLINE indicator in the AUDO_PLAYER.skin then you need to put "BYIND;online;PLAY" in the AUDIO_PLAYER.skin file.
Okay. I have no success today...
I have tested in menu.skin:
I,320,3,47,47,"ONLINE"
BYIND;online;PLAY
No Success.
"BYIND;online;PLAY"
Also no Success.
To test i deactivate and activate the LAN Connection. And switch to another Screens.
Have you a example Skin File for me, where this work?
BYIND is a command.. not an event. You can generate an event with a plugin/script or with a timer.. then have it execute byind... with a timer you'd have to put it on every screen or it would work only on the screen you add the timer...
for instance:
A script/plugin is still a better solution.Code:in screen1.skin: TMR,10 then in exectbl.ini: "TIMER","BYIND;ONLINE;GOOFF<<GOON",screen1.skin "GOON","BYVAR;ONLINE;NOWONLINE||SETVAR;ONLINE;1<<" "GOOFF","BYVAR;ONLINE;<<NOWOFFLINE||SETVAR;ONLINE;0" "NOWONLINE","PLACE HERE COMMAND TO EXECUTE ONCE WHEN SWITCHING FROM OFFLINE TO ONLINE" "NOWOFFLINE","PLACE HERE COMMAND TO EXECUTE ONCE WHEN SWITCHING FROM ONLINE TO OFFLINE"
Ride Runner RR's Myspace
OK,
thanks for your Explanation.
The Timer can i not use, i have a TMR in all Screens. And i can in one Screen just use only one Timer. Or is more possible? Like TimerPlay=3 ?
