Results 1 to 10 of 18
Thread: iLists not working
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Question iLists not working
    The ilists are not working. The playlist shows but will not scroll.
    What am I doing wrong?
    using NEW RR, Tried with Carwings and New Age Garmin
    Any help is appreciated...
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    Using the newest version of Ride Runner
    Aug 2006
    West Allis, WI
    Direct X installed and USEDX=True in RR.ini... Searched couldnt find much else..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can you make a debug log ? it should say something in it if it can't start DirectX..
    Ride Runner RR's Myspace
    Aug 2006
    West Allis, WI
    Quote Originally Posted by guino View Post
    attached is the debug.txt
    thanks for the help
    Attached Files Attached Files
    Dec 2007
    might wanna look into this,
    iLists makes my RR freeze
    guino's Avatar
    Nov 2004
    Toronto, Canada
    "E"rror on InitDX: -2005532109 Automation error" -- there's definitely some missing component.. check that thread above... the DX7VB.DLL is installed with the installshield -- if you used it, in which case you may want to consider update/upgrade your DirectX install.
    MySQL Error
    Oct 2004
    thunder, i assume u used the installer?
    grab latest dx from microsoft
    and use the RideRunner installer
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    West Allis, WI
    DX is definitely up to date. DL'd latest of MS website after I started having the problem. I will Reinstall RR and try that.
    Aug 2006
    West Allis, WI
    Reinstalled RR, ilists still not working in any skin. Carwings or New Age... reaching out for idea...
    Here is a new Debug if it helps.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 01:46 PM
  3. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  4. pink transparency not working if skin is resized by RR
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 02-06-2006, 01:23 AM
