the new rr, will automaticly ask for elevation
@Davedog
could you provide syntaxes of commands: e.g.
- run *.dll's under admin
- add programs to registry
You also mention:
Road Runner config doesn't like running as a non admin either, and it doesn't recognize the audio ports with the driver included in Win7, had to set them manually in RR.ini using Notepad. What exactly did you set up manually in RR.ini?
How is running scripts through the command different from right-cliking and installing under administrator?
what GPS model are you using?
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
And unless your using an old config, the new one does do vista/win7 audio lines.Road Runner config doesn't like running as a non admin either, and it doesn't recognize the audio ports with the driver included in Win7, had to set them manually in RR.ini using Notepad. What exactly did you set up manually in RR.ini?
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
I'm a bit confused. Everwhere on this forum - the concensus was to run RR under "compatibility with WinXP sp2" for audio to work. I did the opposite - left it alone and part of the audio worked. If i choose to run RR.exe under "compability with WinXP" the mixer does not work at all.
BTW, i'm running Windows 7...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
Finished Project
Car Hacking
WorkBlog
Video
correct, RR works perfectly fine in Win7/vista
no need to mess with compatiblity....
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Ride Runner RR's Myspace
I am running vista ultimate and typing from my car now Great work guys .. you rock. Riderunner is up Iguidance, now lets see whats up with the 2140 PSU mon.
