Results 1 to 10 of 12
Thread: Savetoskin-Command Question
    Jun 2007
    Germany
    I must save to my Skin.ini the following Command:
    Code:
    BTN4=EXIT||LIST||PLAYAUDIOFOLDER1
    Before i tested with only one Command. Only Playaudiofolder1 would saved perfect. But with 3 Commands it saved only the first command.
    But i need the 3 Commands, that below black marked.
    Code:
    "SAVETOSKIN;$EDITBUTTON$;EXIT||LIST||PLAYAUDIOFOLDER1||...
    How can i make this?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Use the string replace function of RRExtended to replace "|" w/ something like "@" that can be saved to skin.
    When recalling the command, replace "@" w/ "|."
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2007
    Germany
    you mean:
    "RRStrings_StrRepl"
    Replaces text in a var with other text
    Syntax: "StrRepl;<Var>;<Text to replace>;<Replacement Text;<Return Var>"
    Example: "StrRepl;TrackPath;AC-DC;Metallica;Myvar"
    Result: MyVar = "D:\MyMusic\Metallica\Razors Edge\If You Dare.mp3"
    Thus i must write like in the example above, i think:
    "StrRepl;<var that opens the code like my first post>;@@;||;<what must stand here?>"
    This Code i must write in the skin.ini? What must i write in the <ReturnVar>?
    Thank you for your help!
    Aug 2006
    Sun Diego
    Thinking about it some more, I don't think you can use StrRepl here because it'll probably process "||" like the rest of RR.
    Only thing I can think of it is to do it via AutoIT...
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Toxic,
    Is there anyway to make the button command, just one command that you specify in the ExecTBL?
    Like:
    "B4CMD";"EXIT||LIST||PLAYAUDIOFOLDER1"
    then, u could do:
    "SAVETOSKIN;$EDITBUTTON$;B4CMD"
    maybe?
    edit:
    After looking over the skin commands, you might be able to use "++" in the place of "||"
    so maybe:
    "SAVETOSKIN;$EDITBUTTON$;EXIT++LIST++PLAYAUDIOFOLD ER1"
    Jun 2007
    Germany
    Quote Originally Posted by ws6vert View Post
    Toxic,
    Like:
    then, u could do:
    maybe?
    Uuh, sometimes my exectbl.ini looks like a ...
    Your Tip was good, the Command PLAYAUDIOFOLDER1 now executes also the EXIT AND LIST.
    Thanks.
    Also Thanks to Sal R. Before, i had never looked in the RRextended Notes.txt. There are many good new Commands for me!
    Aug 2006
    Sun Diego
    Quote Originally Posted by toxic000 View Post
    HA!
    Your ExecTBL.ini has got nothin' on my ExecTBL.ini
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    My ExecTBL.ini is about half the size of RideRunner.exe
    Attached Files Attached Files
    2001 S10 ZR2
    Chucks Skin - to old
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Now your just wasting Mp3car server space... could have just pointed to your thread like this
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2004
    St Louis
    Quote Originally Posted by Chuck View Post
    What a showboat!
