Results 1 to 10 of 13
Thread: Problem with playing Playlists (set false path)
    Jun 2007
    Germany
    Hi,
    new problem for me:
    When i would play a m3u File it sends to winamp false paths.
    Example:
    The original from the m3u file:
    D:\Musik\Kerstin Musik\80Žer\16 - Bangles - Eternal Flame.mp3
    D:\Musik\Kerstin Musik\80Žer\1982 - 78 - Culture Club - Do you really want to hurt me.mp3
    D:\Musik\Kerstin Musik\80Žer\1982 - 83 - Toto- Africa.mp3
    When i execute the m3u file from Riderunner, it set this path to the files:
    C:\Programme\Winamp\Musik\Kerstin Musik\80Žer\16 - Bangles - Eternal Flame.mp3
    C:\Programme\Winamp\Musik\Kerstin Musik\80Žer\1982 - 78 - Culture Club - Do you really want to hurt me.mp3
    C:\Programme\Winamp\Musik\Kerstin Musik\80Žer\1982 - 83 - Toto- Africa.mp3
    I would build in my Skin a Playlist Screen, where are the actual Playlist and a Directory List (set to $Playlistpath$), in this screen i would execute my saved Playlists. Where is my problem?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What cmd are you using to play/select the playlist?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2007
    Germany
    Its crazy- only with mouse click in the directory list.
    I have it tested also with the carwings dynamic skin- the same result.
    I open the playlist path in Album browser, click an m3u file, then Riderunner opens the m3u in its directory list. Then i clicked an entry and it sends the whole Playlist (with the false path) to Winamp.
    I build current my own Skin. With the older version from the skin in my Car, RR play m3u lists.
    I will not open the playlist in RRŽs directory List- i will only click the m3u File and play it.
    Is this a Error in RR Config/Winamp Config?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You need to make sure your m3u files have the FULL path to the songs -- not just the "relative" path to the songs based on the current folder.
    Ride Runner RR's Myspace
    Jun 2007
    Germany
    Quote Originally Posted by toxic000 View Post
    i use only m3u with full paths.
    I had now a little solution:
    When i set a button with "select", it functioned as i wants.
    But, if i click with mouse in the directory List, the problem is there.
    It opens the list (show in RR directory list) and send after the next click the list with false paths.
    Jun 2007
    Germany
    Now, after building other screens for my skin, i notice, that this is a normal Function in RR.
    Like in my "Problem" above, i want to double-click in my calls screen in the List on a older Call and use the "DIAL_PHOCO" command. That going, but only with extra Button.
    The same in contacts.skin or in playlist.skin.
    Everywhere the same, with extra Buttons the Commands, i wants to use, goes. But direct in List clicks i have no chance to use different commands, then browse.
    do I think correctly?
    I have now also tested with LSXVoid 3 Skin- in the playlist/contact/calls screens also the same functions like in my Skin.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's a ONPBCLICK event for when clicking an item, however there was never a ONPBDBLCLICK event... I'll add it to next release.
    Jun 2007
    Germany
    Quote Originally Posted by guino View Post
    The ONPBCLICK event i had never found in Skin Commands.txt. Now i had tested that and its great!
    "ONPBCLICK","DIAL_PHOCO" works great, exactly what I wanted!
    For my playlist Screen, i would need a event like "ONDLCLICK" for this:
    "ONDLCLICK","!SELECT",playlist.skin
    If you can add it, it would be great! Thank you!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's no ONDLCLICK but there's ONFILECLICK and ONDIRCLICK.
    Jun 2007
    Germany
    Thank you, thank you, thank you!
    And now we (finally) have a Winner!
    ONFILECLICK was the function, which I looked for!
    I had searched in the skin commands- there are no informations about ONFILECLICK and ONDIRCLICK.
    Thank you!
  1. RRFusion- My Fusion Brain plugin for RR
    By Sonicxtacy02 in forum RR Released Plugins
    Last Post: 12-01-2011, 12:55 PM
  2. RRToaster
    By carputer1 in forum RR Plugins
    Last Post: 02-20-2009, 03:56 PM
  3. Replies: 32
    Last Post: 07-25-2008, 08:36 AM
  4. selecting same song 10 times causes RR to close
    By kegbus in forum RR Bug Tracker
    Last Post: 04-16-2008, 02:59 PM
  5. New Motherboard and now RR Crashes
    By Playerbeat in forum RR Bug Tracker
    Last Post: 10-26-2006, 12:33 PM
