Results 1 to 10 of 17
Thread: Need some mixer help
    Sep 2007
    Export, PA
    Ok, so I split my mixer skin into 2 screens so that I could space everything out.
    My system's sound card, drivers, etc, dont allow for "Bass" and "Treble" adjustment, and it had "Front", "Rear", and "Subwoofer" controls. I tried changing the sliders and buttons to match, but they dont move and nothing changes.
    I did some reading about the Vista mixer stuff, and I'm wondering if my system's mixer is setup similar to that in that it's front *color* and rear *color* in/out...
    If it helps any, it's the Realtek HD integrated sound......cant remember which model exactly...
    Edit:
    DOH! forgot to mention, XP Pro 32bit SP3
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    Aug 2004
    Germany
    mitchjs or guino released a little tool with which you could lookup the real names of the controls for use in RoadRunner/RideRunner. Can't find the link atm, though ...
    Sep 2007
    Export, PA
    yeah thats what i was trying to find, i cant find it either....
    it's mentioned in the file "NEW Vista Mixer Support.txt", which also mentions a folder named "VistaMixerControl", but that folder was not included with my install for some reason?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You only get that option if you install on/in vista. You then should have have a folder named that with all related files, its either in the Riderunner folder or the MJS Gagets folder, can't remember.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    if you're not running vista, which it seems you're not, NONE of this applies
    try looking at the debug.txt, that will tell you about input enumerated by RR
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I should have thought of that.....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Sep 2007
    Export, PA
    there is no debug.txt anywhere in my RR folder...
    i take that back, i had debug disabled....
    but after restarting and going into mixer, then looking at debug, i dont see anything about the different lines...
    One thing about debug i do like.....it gave me the button event i needed to make it beep anytime i click a button..... "ONBTNPRESS"
    Sep 2007
    Export, PA
    Found the "Source"s thanks to Blue!
    now just to figure out which is which........ugh
    Sep 2007
    Export, PA
    Ah Ha!
    Thanks to Blue, we figured it out!
    The names are not standard, but "Front", "Rear", and "Subwoofer" are the proper names to use for the buttons. To get the SLIDER to work, you have to put "VOL;Front" in the "Code" field for the slider.
    THANKS AGAIN ANTHONY!
    Aug 2004
    Germany
    That leads me to a problem I already had with the last RoadRunner version, but also with the newest RideRunner.exe.
    On my CarPC running XP SP3 I get this error in the debug.txt
    Code:
    06.03.2009 16:33:40: Master Vol: Hauptlautstärke/4
    06.03.2009 16:33:40: GetLineControl Failed: 401
    06.03.2009 16:33:40: No Treble Support
    06.03.2009 16:33:40: No Bass Support
    06.03.2009 16:33:40: No Master ON/OFF
    Ok, I lied. I created this debug info on my VISTA PC, because I forgot to copy the debug.txt from my CarPC . But I get the same error numbers.
